Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-24-2006, 10:56 AM
92 talon TSI bloop 92 talon TSI bloop is offline
my 16g keeps blowing vacuum lines?
i just had my engine rebuilt and when I got on the highway the vacumm lines blew off the car idles but when you give it gas it wont rev up without death occuring. any help PLEASE!
Old 11-24-2006, 11:03 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: my 16g keeps blowing vacuum lines?
Hey mang. Please read the rules and post in the right subforums. Welcome to AF.
What boost pressure are you running? Are those little clamps worn out? I bet the reason its running choppy is a boost leak, check www.vfaq.com for the directions to build a boost leak tester.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-24-2006, 11:07 AM
I am pretty much a moron when it comes to turbos I think it was @ 15 lbs or so my mechanic told me it was pushing too much but I think he doesnt know about turbos either. I had the engine rebuilt cuz the piston rings were bad and he said that now the rings are good it is just too much boost.
Old 11-24-2006, 11:15 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
No such thing as too much boost. Well, there is, but I don't think for our problem. It sounds like the clamps are bad/not tight/worn/or broken.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-24-2006, 11:18 AM
The mechanic just called and said he bypassed the boost control. That doesnt sound right to me, dont I need that hooked up? I hate to sound like an idiot but it is my first turbo vehicle my last eagle talon was a 1996 esi.
Old 11-24-2006, 01:35 PM
o.k. I went to the F.A.Q. section and did some reading. (so much info to digest, I am not saying that I still even remotely understand what I got myself int buying a DSM) what would probably help me the most is a link to a vacuum diagram for a 92 TSI awd with a 16g turbo. I think my old mechanic is at his wits end trying to re-install this turbo correctly Thanks all.
Old 11-28-2006, 08:04 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
ok, I'm not sure if you're meaning the vacuum lines or the intake/pressure hoses... I'm assuming that you are indeed talking a/b vacuum lines... in that case, buy you a baggie of zipties ($3 from your local Advance) and ziptie the vacuum lines to the nipples... then they won't blow off. I had the same problem outta my car. I do believe that it's putting too much pressure on the lines for them to stay on the nipples themselves... The zipties will hold them up there and you should be able to boost more than the ~5lbs you can boost without them (what my 14b would boost w/o the vacuum lines on= HUGE boost leak)
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
