Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 11-23-2006, 11:14 PM
anxo69 anxo69 is offline
Durango wont shift to third
I have a 99 durango, When its cold it wont shift to shirt, It will do the high rev, and I'll have to lay off the gas then most of the time it will shift in hard. as it warms it shifts but becomes late and hard. then when its warms . its usually shifts fine. any ideas about this? I changed the fluid and filter but it was exactly the same. Could this be a band adjustment ? and do you know the procedure?
Old 11-25-2006, 07:26 AM
Bear Bear is offline
Re: Durango wont shift to third
Curious, when you changed fluid and filter did you use the ATF+3 or ATF+4 fluid or did you go with DEXRON? I have seen similar transmission problems when the wrong fluid was used.
Old 11-27-2006, 01:27 PM
troy1 troy1 is offline
AF -Advisor
Everything you said points to the inner seal on the Direct drum (3rd) being bad. This is a very common problem and a quaility overhaul kit will have a larger seal so this does not happen again.
Old 07-11-2007, 09:15 PM
troysmith's Avatar
troysmith troysmith is offline
i was having trouble with a 98 up shifting but only when it was low on fuel... and i replaced the speed sensor at the rear of the tranny and cleared the check engine light and cured my problem... hope it helps you
