Old 11-23-2006, 08:52 PM
Jeremy02XType Jeremy02XType is offline
Question about wheel fitments
Currently I have a 1996 T&C LXi which is in depserate need of tires for winter. The van came with 16" wheels 215/65/16 I found a guy selling a set of steels rims 14" 195/75/14 that came off of a 1996 Caravan 6cyl. I'm assuming since the caravan and t&c are virtually the same vehicle and the wheels came off the same yr vehicle they should fit on my T&C just fine. Am I wrong in assuming this?
Old 11-23-2006, 10:26 PM
KManiac's Avatar
KManiac KManiac is offline
Re: Question about wheel fitments
All rims of any diameter will should interchange as long as they have the same bolt pattern. The problem I see here is the tires themselves. The 195/75/14 has a shorter overall diameter and smaller circumfrance than the 215/65/16. To keep your speedometer and odometer acurate, you will need to install 215/75/14 or 235/70/14 tires on the 14-inch steel rims.
Another alternative would be to get a set of 15-inch rims and install either 205/75/15 or 225/70/15 tires.
Then again, you could get a spare set of 16-inch rims and run a new set of 215/65/16 tires.
One more thing, if you have All Wheel Drive (AWD), you MUST put identical tires on all four corners to prevent AWD failure.
Let me know if you have any questions or comments.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 11-25-2006, 11:01 AM
I'm not really concerned about the speedo accuracy. Tires.com has a calculator that will show you the differences so ill be able to know. What i was concerned with was whether or not the T&C's ran larger brakes than the same yr V6 Caravan's. If not then ill get the 14's
