'92 4 wheel drive
I have a '92 Cherokee 4x4 that I just got. What should I know about using the 4 wheel drive? Do I need to lock the hubs? Can I switch into 4WD while I'm moving or do I need to be stopped?
89 CRX SI - ZC DOHC, lambo doors 89 CRX DX - H22 in the making 04 G35 Coupe |
*no need to lock the hubs
*You can shift it while going...from 2wd to 4hi *I presume you have one with the lever that has this pattern: 2wd ...4wd Hi..N...4L *you need to stop and put it into N...and then go into 4L (pull hard) *note of caution..if it is command trac not selec trac, only use 4X4 when ground is wet or on dirt * do a seach on the forum for more posts |
Re: '92 4 wheel drive
Whut Aloha said.......and my.02....Get a Haynes Manual....if you can afford one get a FSM
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
