Old 11-23-2006, 09:40 AM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
rocking feeling in steering
Hey, got a problem with my 4th gen hatch. Getting side to side motion in my steering wheel at all speeds. The faster that I go, the faster it moves back and forth. Lug nuts are to spec, wheels not bent, and it is far more than a alignment vibration, any ideas?
Thanks, Evan
Old 11-23-2006, 12:09 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: rocking feeling in steering
Could be the hub is bent, also could be tread separation within the tires. In any case this problem bears investigation before something lets go. GL
Old 11-23-2006, 08:33 PM
its progressively getting worse...
Old 11-24-2006, 03:36 AM
welfarepc welfarepc is offline
axel nuts ok? you recently do any suspension work? or mess with anything under there? make sure everything is tight. make sure your tires are all up to pressure and try spinning them with the car jacked to see if they are warped.
Old 11-24-2006, 06:09 AM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Sounds like either bent suspension components, misalignment, or bad tires. If it's progressively getting worse, i'd lean towards the tires. The suspension isn't going to progressively bend more and more.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 11-25-2006, 01:44 PM
Hey guys, thanks for the help. I am starting to think that it could be tires. I have a cracked sidewall that I just notice. Could still be the suspension, as I just did a major suspension change. Disc swap, and Skunk2 coilovers, but it was not bad right after the swap, again progressivly got worse. I will throw another set of rims and rubber on that I have and see where I stand.
Evan
Old 11-26-2006, 03:10 AM
Hybrid1990crx's Avatar
Sounds like an axle to me. Does it only do it under a load? As in does it go away when you let off the gas and coast, and it gets worse the more you get into the throttle?
Old 11-26-2006, 01:58 PM
no it does it rolling, can feel it even with clutch in rolling at 5 mph. Does not change with throttle
