How to bypass neutral safety switch
Can anybody tell me how to bypass the neutral safety switch and/or recommend a website with the info?
Thanks in advance for your help Zack |
Re: How to bypass neutral safety switch
First check the switch itself. Using the chart below. To bypass, simply jump B&C on the main harness end.
NEUTRAL SAFETY SWITCH CONTINUITY SPECIFICATIONS Position Between Terminals Park ........................................... "B" & "C" Reverse ........................................ "A" & "E" Neutral ........................................ "B" & "C" Drive ................................................ (1) 3 .............................................. "A" & "G" 1-2 ............................................ "A" & "H" (1) - No continuity should exist between any terminals. To repair/rebuilld it, check out: http://www.jeepin.com/features/nss/index.asp |
Here's the connector on the NSS side. If you look at the main harness, you'll need to "mirror" the image. You can reach everything from up top. If you put a jumper across B&C on the main harness, you'll bypass the NSS. Be careful, you'll be able to start in any gear as well. Also, you'll have no reverse lights.
Like stated...
VEHICLE WILL START IN ANY GEAR Are you having problems starting or are you sure beyond a reasonable doubt that the NSS is the problem Keyed cylinder fubared can cause a "no start" situation Bad ignition switch can also cause the same The rod that goes from the back of the keyed cylinder to the ignition switch,if it is bent or not in position will cause a no start situation Here is a write up on how to clean the NSS http://jeepin.com/features/nss/index.asp
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
