Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 11-22-2006, 04:25 PM
phaedrus877 phaedrus877 is offline
Idle rpm rate issue
Hi guys,
I'm having an issue with my 95 del sol for a month or so. When I'm in neutral and don't have my foot on the accelerator , the rpm of the vehicle should be pretty much constant. But for some reason the rpm increases to about 1.5-2 for a few seconds and then drops down again without any pressure on the accelerator. I've noticed my mileage drop too.
I'm not sure what the problem is and would appreciate any help or comments.
Thanks a lot
Old 11-22-2006, 04:41 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Idle rpm rate issue
Did anything out of the ordinary happen before this started? It could be dirty fuel. Try some fuel system cleaner.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-23-2006, 01:44 PM
Thanks for the reply.
I'm not sure if it's dirty fuel. I've filled the tank a couple of times at different gas stations. Want to have an idea as to what the problem could be before I take it to a mech,
Thanks
Old 11-23-2006, 02:09 PM
NA is Best!
Hondas do the idle surge thing becuase of all kinda of problems. Fuel, sensors, vacuum leaks, ect. Is your check engine light on by chance?
Old 11-23-2006, 05:34 PM
Nope the check engine light isn't on....which sensors are you talking about?
Old 11-23-2006, 05:48 PM
NA is Best!
TPS, MAP, alot of sensors can cause it but if your not getting a check engine light it's most likely not sensor related. It may be your IAC valve. They get stuck open sometimes and cause that problem.
Old 11-23-2006, 05:53 PM
can I check if the problem is actually the IAC valve?..how much does it cost to fix it..or can I do it myself? though I'm limited in my expertise to only doing oil changes, or fixing lights and some minor electrical things.
Thanks
Old 11-23-2006, 06:43 PM
NA is Best!
http://honda-tech.com/zerothread?id=1564019
Try that.
Old 11-23-2006, 06:48 PM
Thanks for the info...i'll check it out..
later
Old 11-26-2006, 12:25 PM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
lol I just let my car bubble away... my idle hasn't been constant since I bought the car, but then again the motor is modded... is your motor modded? Knowing if the motor is stock or modified can help us help you more effectively. Makes troubleshooting less of a crapshoot and more of a definitive cause/effect ratio
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
