Old 11-22-2006, 02:07 PM
MyTaurus8AChevy's Avatar
MyTaurus8AChevy MyTaurus8AChevy is offline
Question Remove/tighten gear shifter handle
How do you remove/tighten up the gear shifter handle for the Taurus with a center console? What's the trick? Ours is very loose (around 3/4 inch play). I know this much play shouldn't be in the handle (the part you grab with the button). On our 89 Cougar there was a 'C' clip that you removed at the bottom of the handle, but no such clip on this one
Old 11-22-2006, 03:21 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Remove/tighten gear shifter handle
I assume you're referring to your 2004 Taurus.
I'll check the manual for the 2002 this evening or Friday. Is the play rotational play or linear play up and down? Can you determine if the play is also in the shaft, or just in the knob?
-Rod
Old 11-22-2006, 04:40 PM
Smile Re: Remove/tighten gear shifter handle
Yes.
Rotational.
Just the knob. If there is a set screw lose that would explain all of this, but I didn't see one
Old 11-22-2006, 10:47 PM
shorod's Avatar
SHO No Mo
Per the service manual for a 2002 Taurus:
Transmission Selector Lever Knob
Removal
  1. Slide the plastic sleeve down.
  2. Remove the screws. [They appear to be Torx from the diagram - Rod]
  3. Depress the button and remove the selector lever knob.
Installation
  1. Follow the removal procedure in reverse order.
-Rod
Old 11-23-2006, 08:57 AM
THANKS Rod! This worked like a charm
It was even looser than I first thought. Ford makes a solid wood shifter handle for the 2005-2006 Taurus and now that I know how to replace it I think I'll add it
