Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 11-22-2006, 02:50 PM
timd timd is offline
2004 Eddie Bauer 5.4L fuel filter
Please tell me where to find the fuel filter on a 2004 Expy, Eddie Bauer, 5.4L, 2WD.
The dealership says its below the driver's seat. Looking from underneath, I see the fuel tank and there are two lines running toward the top of the engine from the fuel tank labeled "Fuel Lines". Looking under the hood, I can't see the lines nor can I see a fuel filter. The filter I got from O'Reilly's had two inlet fittings and one outlet fitting. Knowing O'Reilly's , this may not be the right filter. Any help and a PICTURE of the filter location would be appreciated. Thanks a bunch!!
Old 11-23-2006, 12:35 PM
sparkslg sparkslg is offline
Re: 2004 Eddie Bauer 5.4L fuel filter
fuel filter is located under fuel tank , inside of a cover on the tank itself. Cover comes off with just a screw driver and will give you clear access to filter . Sent picture from service manual , hope you get it
  1. Insert a medium flat-blade screwdriver in the the fuel filter protective cover tabs, turn 45 degrees, and gently remove the cover from the tank.
Vehicles equipped with 4.6L and 5.4L (2V) engines
  1. Disconnect the fittings.
Old 11-24-2006, 08:06 PM
Thanks, sparkslg. The pictures didn't show but your description helps. I will give it another shot. Thanks again.
