View Poll Results: Replacing the fuel pump/sending unit....do I.......
Drop the tank 18 38.30%
Take off the bed 19 40.43%
Run the truck off a cliff, claim the insurance money 10 21.28%
Voters: 47. You may not vote on this poll
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-22-2006, 12:34 PM
whalerboy's Avatar
whalerboy whalerboy is offline
Replacing fuel pump....let the debate begin!!!
Well, I think it's about time for me to replace my sending unit. My gas gauge needle flops around like the mixing board at a wu-tang clan concert.
I'll replace the fuel pump as well (you KNOW if I didn't it would crap out on me a week later...i got over 100k on the original one)
The debate?...Remove the bed or drop the tank?
I dropped the tank on my friends truck last year, and the thought of lying on my back on the cold floor, getting a mouth (and eye) full of rust, while praying that I don't tweak/snap/break/screw up a fuel line doesn't really excite me.
It seems to me, from reading several posts that the masses are split on this issue...let's settle it for good!!!
I ALWAYS fix it right the last time!
Old 11-22-2006, 12:52 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Replacing fuel pump....let the debate begin!!!
It is more of a personal decision than a debate.
What is good for the goose is not always good for the gander.
Also you forget to put in chop a hole in the bed to replace it.
Beside it is not a easy decision and a lot of stuff has to be considered and the situation has to be looked over good.
Ever truck is different.
A person has to consider several things before he makes a decision on it.
Year make and model and what kind of bed?
Some with fifth wheels and campers and all sorts of other stuff on or in or around or on top of bed.
Rusty bed bolts and fuel tank straps rear bumpers and trailer hitches hooked to bed..
Also what tools and jacks and lifts and people helping exc.
MT
Old 11-22-2006, 01:01 PM
whalerboy's Avatar
It's a 2001, extended cab, short bed. All the bolts (bed and strap) look to be in about the same condition. I have all kinds chainfalls, come alongs, and rigging to be able to pick the bed off if nobody is around to help me. No 5th wheel, and not much else in the way of pulling the bed off.
That's the way I'm leaning. I've done it the other way, so if I pull the bed off, I'll know for sure which one is the bigger pain in the ass. That way I can travel back in time and tell myself which way to do it....
Old 11-22-2006, 04:39 PM
MT-2500's Avatar
AF - Advisor
That is a good way to find out.
But as said every truck may be a different situation.
Some perfere the bed remove and some just drop the tank.
And still yet some still chop a hole in the bed.
Either way is usually not to hard. But can be a pain at times.
Good luck and choice a good OEM type fuel pump so you will not have to do it many times.
MT
Old 11-22-2006, 06:32 PM
spackelman spackelman is offline
I did the drop tank thing on my old dodge. No big deal.
When I have to do it on this truck, I will probably lift the bed. It will give me the chance to eyeball everything from the cab back from the topdown. I can repair / replace / tighten and throw some touch-up paint on anything that needs it.
May even do the rear brakes.
Seems like the best way. Time wise, probably longer... you have to spend the time to align the bed.
2002 Silverado 2500HD Crew Cab, Full Box
8.1
K & N Intake
Pioneer DEH960MP w/ Pheonix Gold Octane 5/4 Amp
Polk momo6500 Front Polk momo 650 Rear
Bulldog Auto Start
Old 11-22-2006, 09:20 PM
NoRiceHere01 NoRiceHere01 is offline
i dropped my tank in my driveway by myself with a floor jack and some elbow grease.i had my girlfriend there as another set of hands and to spot, but i could have done it alone.if i had a garage and the equipment or extra people i would agree with lifting the bed too tho.its up to u.i really dont think either one is too hard on these trucks.just to let u know,however,and i dont think i saw it in any posts here: you're correct on one point in particular.if your replacing the sending unit then u r indeed replacing the pump with it.its one unit and its not cheap.i think i got reamed about $350 if i remember correctly.but your right about another thing too.if it wasnt one unit and u didnt replace the pump, it would most certainly crap out on u in another week
Old 11-23-2006, 12:05 AM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
I have done it both ways and it just depends on the situation as stated above. All fuel pump mfgs are now recommending that you drop the tank, drain it, throughly clean it and then put the new pump in. Some are talking about not selling the pump seperate from the tank, they are wanting to sell a sealed tank, pump assy, to stop contamination from not cleaning the tank. They say that the #1 killer of fuel pumps is a dirty tank.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 11-23-2006, 06:43 AM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
I voted for taking the bed off, because that's what I plan to do when my number's up.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 11-23-2006, 05:57 PM
16th hippy 16th hippy is offline
done quite a few pumps on pickups....if you have about 3 other people and no heavy tool boxes in the bed, it ALOT easier(chainfall hoist should work with correct balancing in leiu of other people). with either way, you will get the mouthfull of rust/dirt. 8 bolts for the bed, and 2 plugs for wires, and a couple bolts at the filler neck. if you lift the bed off, make sure when stetting it on the bumper that you have that vertical brace/bar on the bumper....if not you may collapse the rear fenders/bed area.
this method is only my opinion, and when using said method, i am using a lift and air tools, so it makes it easier to pull the bed. good luck!
Old 11-23-2006, 09:28 PM
4x4playhus 4x4playhus is offline
Smile Re: Replacing fuel pump....let the debate begin!!!
If you opt to remove the bed mark some referance points with a crayon. Three on the back of the bed. Center both bed and cap, inside corners lt, rt, then use a carpenders square. Set your square on the inside of bed corners, slide ruler up to cab at corners and lock the ruler in the square. If your cab was square to start with it should replace square using this in reverse. This saves so much time. If it's not square cab to bed but square on the outside when you look at it. Note the distance from cab at lt corner and at rt corner.
Good luck.
Old 11-26-2006, 08:00 AM
fleettech fleettech is offline
I voted to pull the bed.it all depends on the truck we get alot at work with a bed full of junk and tool boxes or flatbeds. I think for the average P/U pulling the bed is faster,easier and less of a pain in the ass than being a contorsionest to get the lines un hooked and wrestle the tank if its got fuel in it murpheys law applies here when a fuel pump goes out the tank will ultimatly be full.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 12-09-2006, 12:20 PM
silvychick silvychick is offline
I say remove the bed. It takes a total of about an hour to hour an a half. You can't just buy the sending unit. The sending unit is part of the fuel pump. Cost is about 400 dollars.
Old 12-13-2006, 12:54 PM
Slowprocess's Avatar
Slowprocess Slowprocess is offline
Send a message via Yahoo to Slowprocess
I installed a new Walbro 255 in mine Monday night and it was really easy removing the bed. Had it off in about ten minutes. Now the Walbro install was an totally different ballgame(since they don't make a drop in replacement for this truck). Still, its in and I'm no longer running lean on the big end of the 1/4.
Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires
Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft
Old 12-20-2006, 04:45 PM
tom3 tom3 is offline
Had several Chevy trucks over the years. I put four eyebolts in the garage ceiling, use cargo straps to lift the bed off, push the truck out from underneath. Wash everything off good and just sit on the frame and change the pump. Wouldn't do it any other way.
Old 01-08-2007, 08:27 AM
Blue Bowtie's Avatar
Registered Offender
I've become accustomed to removing the tank, since removing bodywork on a van, Blazer, Tahoe, Suburban, or other vehicle is not generally an option. It's only four bolts (sometimes two), three lines, and one electrical connector, and the tank can be lowered. Removing the bed seems like a lot more work than that. Since the late 1980s, the bolts have all been Stalgard coated, so corrosion may not be as big a problem as you might anticipate. Good penetrating oil is always advisable, even if you're removing bed mount bolts, bumper bolts, etc.
Moreover, its a good excuse to clean out accumulated debris between the tank and rock shield, clean out the tank itself, and get a good look at the always suspect electrical connections.
Closed Thread
