Old 11-22-2006, 07:15 AM
rl0gin rl0gin is offline
Windshield wiper problem
Hey guys, I just got a 1997 3000GT and I'm having a problem with my winshield wipers, I keep blowing the stupid fuse for them. I thought maybe it had something to do with the way the amp was wired in the car, so I completely disconnected it, and the wipers would actually work for a little while after that. But tonight, I tried to use them, and they got about half way up the window, then the fuse went again. Now everytime I put a fuse in, it's back to blowing as soon as I turn the key to the on position. Anybody have an idea on what I should be looking for to fix this? Thanks.
Old 11-22-2006, 11:09 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Windshield wiper problem
look at the wires in the plug that goes into the wiper motor, somethings shorting.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 11-22-2006, 08:04 PM
Think I located the problem. If I unplug my rear wiper motor, the fuse doesn't pop. For now I just left it disconnected, but I'm assuming I have some sort of problem with the wiper motor. I guess it's one more thing to put on my list of things to fix. lol
That's a damn nice looking 3kGT you have there Twizted.
Old 11-22-2006, 08:37 PM
miami3000gt miami3000gt is offline
my back wipers dont work or i dont know to use start them
same thing with water in the front...
1995 mitsubishi 3000gt Base Model - working on her
Old 11-23-2006, 08:55 AM
Igovert500's Avatar
blue + red light magnet
For the back, there should be a button to the right of the steering wheel, on hte dash.
For the water on the front, pull the wiper lever towards you (the driver).
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-23-2006, 07:13 PM
AutostradaVR4 AutostradaVR4 is offline
you may have something clogging the jets (dirt, old wax). Us a small needle to clear it out. can you hear it pumping?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-24-2006, 07:17 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
also, the pump in the washer fluid reservoir tends to go out after 10 years or so. so if all else fails, remove the fluid reservoir and inspect the pump.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-24-2006, 07:25 PM
i tried cleaning them and still nuthign and no u cant hear anything
my back one works
