Old 11-21-2006, 11:32 PM
SaphusGT's Avatar
SaphusGT SaphusGT is offline
Power/Economy Switch
So yeah... I got the replacement eco/pow switch from my local mitsu dealership... problem is this... I have tried 3 or 4 times to get that part of the console out to replace the old one (gummed up and doesn't work) I can not seem to get anywhere near the thing no matter how hard I try... how is this done?
Old 11-22-2006, 03:44 PM
AutostradaVR4 AutostradaVR4 is offline
Re: Power/Economy Switch
Off topic: Werent you around here before? or am i thinking of 3si?
in any case, welcome (back?)
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 11-22-2006, 05:52 PM
Igovert500's Avatar
blue + red light magnet
I don't have active exhaust, where does the button go, refresh my memory. In any case, all those button panels in my car, I'm able to pry and pop up with a flathead screwdriver.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-22-2006, 07:01 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
^^ My guess is that he has the ATX. The pwr/eco switch is located at the top left on the shift column. However, when it comes to installing it, I have no idea.
Old 11-22-2006, 10:31 PM
SaphusGT's Avatar
Yeah I was here before... After blowing an engine, getting exhaust work and stripping the back end... I'm back.. & now my 3kgt is a project car with a 2007 accent as my driver/winter car so yeah... thanx for the warm welcome.
BTW what do you mean by "ATX"? this is not a term I've heard Of yet... can you explain the differences of it to me?
Old 11-23-2006, 08:57 AM
Igovert500's Avatar
ATX = Auto transmission, as opposed to manual.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-23-2006, 06:46 PM
SaphusGT's Avatar
Yup it's definately auto... which is why i can't stop messing with the tranny... its kinda fun... kinda
Old 11-24-2006, 01:46 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
What all are you doing to the project??
Old 11-25-2006, 12:53 AM
SaphusGT's Avatar
Well, lol for starters trying to get the eco power switch replaced ( ) Then maybe dropping a 4G63T. It all depends...
Old 11-25-2006, 03:28 PM
VR43000GT's Avatar
^^^^ Why go to so much trouble?
Old 11-26-2006, 02:14 PM
SaphusGT's Avatar
Mainly because I'm a broke performance guy... + my switch doesn't work & I've always wanted to know if it makes any real difference... not to mention, if you love your car you want everything to work right?
Old 11-26-2006, 02:19 PM
VR43000GT's Avatar
It would be easier (by far) and cheaper and faster to drop in a 6g72TT.
Old 11-26-2006, 02:21 PM
SaphusGT's Avatar
Tell me more about that particular engine... I'm still researching
Old 11-26-2006, 05:08 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
SL3000GT meant why go to the trouble to put a 4G63 turbo into your car when you can just slap on 2 turbos from a 3000GT VR4 or Dodge Stealth TT. they will bolt right up. the 6G72 engine is what is in your car, its in every 3000GT/Stealth.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-27-2006, 11:46 AM
SaphusGT's Avatar
So what kind of prep mods am i going to have to run to get a TT working correctly?... ...This car is going to be spending the entire winter in the garage with the engine out just modding it and building it up....
