Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-21-2006, 09:17 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Upgrading Fuel system... opinions
Well it is time for me to upgrade my fuel system. I will be buying a Walbro 255HP fuel pump tomorrow. Now I really want to get some power out of my Big 16G. I have heard that max boost on pump gas is around 24~psi. So since I will be using a SAFC2 which injectors should I use that will satisfy the turbo. Also I will get megan racing fuel pressure regulator and maybe a fuel rail ( is it that necessery to have aftermarket fuel rail). So basicly : I want to get about maybe 19psi out of my 16G if possible. I am confused about the injectors since I really dont know whats the biggest injectors safc can control. If I get say 750cc with the walbro and megan fuel pressure regulator, using the safc to tune it hoiw many pounds of boost should I be able to get out of the Big 16G keeping my engine on the safe side of course.
thanks guys
1997 Eclipse GSX
Old 11-21-2006, 09:31 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Upgrading Fuel system... opinions
You can't controle 750cc injectors with the SAFCII. Compensation is only +/-50%. Please don't get the Megan Racing FPR. It's not somthing I personaly would trust with fuel. Get a Aeromotive 13109 with Marchel liquid gauge. Don't bother with a fuel rail, and buy a fuel pump rewire kit.
Thank-you drive through..
DSM geek
Old 11-21-2006, 10:38 PM
steviek's Avatar
steviek steviek is offline
get 550's kevin wrote a nice write up on 550 v 660. He decided on the 550
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 11-21-2006, 10:39 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
thanks guys
Do what scottsee says.
Also, Why would you want to spend 250 dollars on an SAFC when you can spend 500 and just get DSMlink. Than you can run whatever size injectors you want.
We have a saying.
Mod right or mod twice.
Even if you never go bigger than a 16g, You can make more power off of it with dsmlink than with a SAFC.
1991 GSX 2.3 Stroker
Old 11-22-2006, 12:33 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
If you really want to go with the AFC then 660s is the biggest you should go...but if you are only looking to run that much boost then 550s are fine...and you dont need a fuel rail...and get the Aeromotive FPR...dont waste your time and money on the Megan one...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 11-22-2006, 12:55 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
IIRC, 680's is the absolute biggest injectors that the SAFC can handle without it being a complete total waste of money.
95 Talon TSI AWD
97 Eclipse GST
