Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-21-2006, 08:18 PM
JimLovatt JimLovatt is offline
japanese evo3 --> 98 gs-t 4g63
Hello, I bought a new japanese motor online to replace ruined engine. The module (distributor?) at the end of the rear cam is different, old one has a piece that bolts onto end of cam, new engine has no threads on cam to install old sensor unit. Old module has 3 wire connector, new one has 4 wire. can you please help me get this car running? jim
Old 11-21-2006, 09:27 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: japanese evo3 --> 98 gs-t 4g63
You mean the Cam Angle Sensor? I've never done or helped with an Evo3 swap. I don't know if they are like the 96-96 or like the 91-94/97-99
DSM geek
Old 11-22-2006, 09:02 AM
Yes, its the cam angle sensor. I need to make the one on the new engine which mounts to the cam into a slot, work with the wiring on the old engine, which mounted to the cam with a bolt into threads.
thanks for any help. jim
Old 11-22-2006, 09:22 AM
tntmst tntmst is offline
this might help
http://www.roadraceengineering.com/1gcasin2g.htm
do some searching on this site and it should answer your question
Old 11-22-2006, 11:01 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Some pictures would help tremendously.
95 Talon TSI AWD
97 Eclipse GST
Old 11-23-2006, 09:12 AM
Thank you TNTMST! I ordered that wiring assembly, looks like its exactly what I need. jim
Old 11-28-2006, 01:22 AM
let me know how your install is going. i'm currently doing the same. maybe we can help each other out
