Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 11-21-2006, 08:09 PM
jbh_customs jbh_customs is offline
Send a message via MSN to jbh_customs
2001 LS V8 - Door lock issue
Any ideas of what this might be would help alot, its a 2001 LS v8
The Problem:
The problem is with using the key fob. It works fine when the car has NOT being sitting locked for more then 30 min. It will unlock, lock, panic, role the windows down, etc from any distance. However when the car has being sitting locked for more then 30 min the key fob does not do anything, its like it has no battery. I assume the problem is with the car itself.
As a result i have to unlock the car with the key and then the alarm goes off. After the alarm turns on, everything on the key fob will work again.
Please help, this is an annoying issue.
Old 11-21-2006, 10:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2001 LS V8 - Door lock issue
Is this the factory key fob? Do you have another key fob to try?
I doubt a second key fob will have any effect though, it sounds more like a problem with the module in the car (Driver Door Module or Front Electronic Module). Using the key to unlock the door should also disarm the factory alarm. There is a disarm switch in the key cylinder.
-Rod
Old 11-22-2006, 12:27 AM
thanks for the help, i did some playing around and a fuse was gone. All is working great now.
Old 11-22-2006, 12:34 PM
shorod's Avatar
SHO No Mo
Interesting. Hopefully you don't discover there was a reason the fuse was removed.
With the fuse installed, have you tried unlocking the door with the key to see if the alarm still sounds or not?
-Rod
