Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-21-2006, 07:27 PM
kennylee kennylee is offline
No Power to 200 Ford Exp ODB2 COnnector
I have a check engine light on in my 2000 For Explorer so I went and bought a cheap reader that powers itself off of the connector under the console. However, when I connected it up, it would not work. I then measured the power between pins 5 & 16 and i measured 0 volts. So then I popped the fuse cover and found that there was no fuse in the DLC slot. So I put one in and I was unable to get any voltage to this pins. Any ideas on what to try next?
Ken
Old 11-21-2006, 09:18 PM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
Re: No Power to 200 Ford Exp ODB2 COnnector
Check fuse #5 and #17 in the interior fuse box.
Old 11-21-2006, 10:15 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Also, try between pins 4 and 16 (pins 4 and 5 are both grounds). Can you tell whether or not there is a terminal in the location for pin 5?
As virgamanda mentioned, fuse 17 in the Central Junction Box is the fuse for pin 16 of the DLC. Make sure that is the fuse you installed.
-Rod
Old 11-22-2006, 06:37 PM
Thanks! Went looking and found that the Cigerette fuse was blown! Replaced the fuse and put one in 5 and I got the codes P0171 and P0174 -- System To Lean Bank 1 & Bank 2. What do I need to do to fix this?
Ken
Old 11-22-2006, 06:50 PM
Look for a vacuum leak.
Old 11-23-2006, 07:34 AM
shorod's Avatar
SHO No Mo
Per the factory service manual, for code P0171 and P0174, check the following:
  • Fuel system.
  • Excessive fuel pressure.
  • Leaking/contaminated fuel injectors.
  • Leaking fuel pressure regulator.
  • Low fuel pressure or running out of fuel.
  • Vapor recovery system.
  • Induction system:
- Air leaks after the MAF.
- Vacuum Leaks.
- PCV system.
- Improperly seated engine oil dipstick.
  • EGR system:
- Leaking gasket.
- Stuck EGR valve.
- Leaking diaphragm or EVR.
  • Base Engine:
- Oil overfill.
- Cam timing.
- Cylinder compression.
- Exhaust leaks before or near the HO2Ss.
-Rod
Old 11-23-2006, 11:42 AM
sparkslg sparkslg is offline
if you have a 4.0 sohc engine it is very common to have a vac. leak at the intake manifold gaskets ( lower and upper ) Ford has a nice little kit that has both sets of gaskets and also cam chain tensioner ( kit was part of a service bulletin) This will give you lean codes for both banks and like I said is very, very common
