Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 11-21-2006, 06:55 PM
ntimeol ntimeol is offline
d15b motor swap
I am getting ready to do my first motor swap I have a 94 del sol with a b15b7 in it right now I was wondering if I will need anything more. I just want to make sure i have everything before i start I already have these parts though.
Transmission
ECU
Distributor
Starter
Intake Manifold
Exhaust Manifold
Alternator
Vtec Solenoid
Half Shaft
Throttle Body
Sensors
Fuel Rail
Injectors
Old 11-21-2006, 07:57 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: d15b motor swap
Are you saying you're swapping the JDM D15B? If so you'll need to convert to run a single wire O2.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-22-2006, 12:07 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
Re: d15b motor swap
Save yourself the trouble of the D15B.. that swap is a BITCH... go with the D16z6 instead.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 11-22-2006, 08:29 AM
Re: d15b motor swap
what all would i need with the d16z6 swap and why is it so hard to swap the d15b?
Old 11-22-2006, 10:28 AM
NA is Best!
Re: d15b motor swap
Wiring. For the Z6 all you'll need to wire is the vtec. Other than that you can use your stock harness.
Old 11-22-2006, 01:44 PM
Re: d15b motor swap
how much would it cost to buy the d16z6 and everything I would need to do the swap. Also what would i need.
Old 11-22-2006, 02:15 PM
NA is Best!
Re: d15b motor swap
You can use most of your stock parts like trans, mounts, axles and whatnot. Basically all you need is the motor but the z6 trans does have shorter gears and most motors come with the trans so either iether. Z6's are all over the place. You can proably find a local one if you check ebay.
Old 11-22-2006, 02:20 PM
Re: d15b motor swap
so what type of wiring harness will i need and what type of motor mounts thanks for all your help guys...and gal.
Old 11-22-2006, 08:58 PM
Re: d15b motor swap
is the d16z6 also called the Zc or is that a diffrent motor?
Old 11-22-2006, 09:08 PM
NA is Best!
Re: d15b motor swap
Completely different. I just call the D16Z6 a z6 for short. You can use your stock harness and mounts. You just have to run the vtec wires seperate.
Old 11-26-2006, 12:23 PM
94SolGrl's Avatar
Re: d15b motor swap
You can go on hmotorsonline.com and find a complete z6 swap (mounts, motor, trans, wiring, ecu, all of it) for under $1000 shipped.
~*Emily*~
HOW TO POST PICS!
Old 11-26-2006, 05:20 PM
NA is Best!
Re: d15b motor swap
HMO and 94SolGrl own all.
-- fixed for you
