Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-21-2006, 06:15 PM
rhinton rhinton is offline
Fuel Injector question and information
I have a 1996 Pontiac Trans Am. No crazy mods, engine is all stock besides the Trickflow air intake, but this was an issue even before that add on. Everything else is just suspension upgrades and/or brake upgrades.
Symptoms:
Does not start up anymore on one turn over. Sometimes takes awhile to start up. Sometimes I have to prime the fuel pump several times as it seems like I'm not getting enough fuel to start up the engine. (I hear the fuel pump working everytime however, so I know it's getting fuel.)
Also, while cruising at high speeds, I can heard some sort of "ticking" or "clicking" and it slighty feels like the engine isn't getting enough gas.
Most of the time it only starts to make this noise when I turn on the AC or heater and put the engine under a load. Even when I turn the AC/Heater off, it will continue to make that weird "ticking" noise whenever I'm cruising down the road or slightly giving it a little more gas. If I stomp down hard it will stop. But it will continue again while applying little gas pressure.
What I've done so far:
I have put new injectors in but they are the 19 lbs/hr and were very cheap, but they do work for my car as I got them from SLP.
I've changed wires, changed spark plugs, changed battery, and added a new starter.
Opti was changed but it has been awhile.
What I have been told by a mechanic:
I've taken this thing in to get it checked out (long time ago) and he said there are some misfires in some of the cylinders and that new injectors were needed. Thus the reason why I got new injectors. But the issue remains.
Today I just got a new catalytic converter on the passenger side of the car. The muffler guy told me the only reason why I needed one was because the engine was running rich and it burnt up the inside of the cat.
Could this be fuel injected related?
Are the stock fuel injectors for the 5.7 engine 24 lbs/hr? Should I get those instead?
Why would the car be running rich with wrong injectors anyway? Wouldn't the computer adjust? Or not?
And if the car is running rich, why would it hesitate? Why would it not start up with one turn over? Is it because of too much fuel in the cylinder?
The muffler guy told me, if I don't get it fixed then my catalytic converter will be burnt out again and possibly the more expensive one on the driverside. I don't want that to happen!
This is all I can think of at the moment. Please help if possible.
Thanks.
1996 Pontiac Trans Am- 85,000 miles Black/Black leather interior, auto trans, BMR rear lower control arms, Trick Flow Air Inlet, Russell brake lines, slotted front rotors, Auburn differential 3.23 gears with bolted alum. girdle. Trying to fix my repairs now. So sad really. But with every replaced part, comes a better part!
Old 11-21-2006, 06:52 PM
poormillionaire2 poormillionaire2 is offline
Re: Fuel Injector question and information
Sorry to tell ya' bud, but that has all the makings of an opti problem. The ticking you hear are mis-fires. Time to change the opti.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 11-21-2006, 08:14 PM
You've got to be kidding me?
You sure it's nothing with the injectors? I know the opti controls timing but would it cause the vehicle to run rich like that? And even not cause it to start up on one or two turn overs?
Old 11-21-2006, 09:06 PM
Yes, the opti can cause your car not to start. I had the same problem a few years ago.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 11-21-2006, 09:28 PM
Did you do the opti yourself or did you have someone else do it?
How reliable are those cap and rotor pieces?
I really don't feel like spending $300 just for a new opti when while I do the opti I might as well do the timing chain too.
Old 11-21-2006, 09:35 PM
Well, that opti went out right after I got the car and before I knew much about cars, so my mechanic did it for me. Full tune up. It was expensive.
If it went out now, I'd do it myself though. I'd probably replace the water pump while its off too.
But if your opti is somewhat new, you might be able to get away with just doing the cap and rotor. But I've never just done a cap and rotor for the opti, so I couldn't tell you if they are any good.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
Old 11-22-2006, 09:18 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Opti is possible, but, I didn't catch in all that what the fuel pressure is at?
Old 11-22-2006, 10:46 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
it would be running rich because the fuel isnt burning (due to opti messin up) and no spark igniting the air/fuel in certain cylinders. well i guess it wouldnt be running rich but it has that effect on the exhaust/02 sensor(s) side. and that might be making the computer give less gas to fix the problem of running rich when its not its just not burning gas. make sense? i dont know if thats the problem but it answers your question i guess
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 11-22-2006, 10:53 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Fuel pump check valve is done. One of the first sign of a pump on the way out. On average it probably takes 3 attempts before it will start, correct?
(BTW, SLP injectors are cheap for a reason. They are complete garbage. I had them and unfortunetly turned a few others on to them , well it made me look bad cause all our injectors failed within 5k, some leaked and some fried the solenoid) Also never switch sizes without a tune. Clean the stockers and put them back or if your sure they were messed up check out ebay or I can supply you a stock set I have.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-27-2006, 05:28 PM
Okay, sorry. Was trying to get back to this sooner but had the Thanksgiving stuff going on.
The Opti was probably done around 50k miles. Can't remember off hand and don't feel like digging through paperwork.
The water pump was also done when that was replaced. So I'm not sure if I would need another water pump seeing as I'm on about 86k now. But then again, I'll get your opinions.
I now kinda understand how the Opti could cause it to not crank correctly and when asked about if it takes 3 times? Not really. Usually on the second try it'll crank right up.
Sometimes if I prime the fuel pump about 2-3 times it'll crank up right away.
I still have the stock fuel injectors, but I'm not sure if they are any good and that comment on those cheap SLP injectors. Yeah, I had to send one back before because it was spraying fuel out the side. It was pretty bad.
I think I'll go ahead and order an MSD opti, not the $500 one because I can't afford that. I'll also get a new timing chain along with the sprockets. And get the 160 degree thermostat, but of course I'll need that Hypertech thing which I'll just have to order later.
Anything else I should try?
I'm thinking I'll just try the fuel injectors last if the opti replacement doesn't work.
Old 11-28-2006, 02:32 PM
wrightz28's Avatar
Why, FormuaLT1 and I are telling you it sounds like the fuel pump is failing
Why not save your time and money and run some pressure checks.
Old 11-29-2006, 07:27 AM
My fault. The pressure was checked a while back ago. I'm not sure what it registered because I don't have the tools to do that. But the mechanic said it was all good. He thought the injectors were just going bad.
I don't think it's the fuel pump because it's getting too much fuel. But I'm lost in that aspect of the engine and not sure if the pump could cause the engine to run rich.
The last time I did a code check, it registered some miss fires in one of the cylinders. I'm thinking it's only on one side. That would also explain the burn up of the cat on the passenger side and not the driver side one.
Right?
Old 11-29-2006, 09:33 AM
wrightz28's Avatar
I always say this in general, if you're going to work on a EFI car, you need a fuel pressure gauge and a scanner in your tool box arsenal.
From experience, on my old Buick PA, I pressure tested and flow tested it when I was in fuel systems training. It was in perfect order. A little less than a year later, guess what? I go out, start the car, let warm up for a few minutes while getting my lunch together, come back back out, and bam, just as I get in, it stalls, first time ever. Go to roll it over, and eh eh, no, the pump just abruptly quit.
There is always the chance that it may not be pump. But when you're trying to diagnose a problem on a EFI, computer controlled vehicle, nothing can be assumed. It needs to be confirmed as not a suspect.
You can get a basic gauge for a reasonable amount (30-50 bucks). I just hate seeing parts shotgunned in the prayer one will hit the problem area.
BTW, I 've heard nice things about the injectors from those guys with blue ovals in their logo
Old 11-29-2006, 01:50 PM
I read up on how to change out the fuel pump.
Man...
Sounds like it's going to take just as long if I were to change out the opti and the timing chain. I have to change that timing chain eventually, sometime in the near future. Don't want that thing breaking.
I'll go out and get a fuel pressure gauge, probably today, when I get some oil. If it does register off, or not enough pressure, then what then? Does it just mean the pump isn't working correctly?
Also, if I was to get a pump, what kind should I get? Am I going to have to use that covering that is on the old one? (was getting this info from the shbox.com site)
I'm going to have to go home and read in the repair manual about this mess.
Old 11-29-2006, 02:14 PM
FormulaLT1's Avatar
Fight the powwa!!!
Alot of mechanics will check fuel pressure with vehicle running. See it is within specs and move on. However, this does not mean your pump is not the cause of your issue's cause the pump is suppose to meet the high demand of your vehicle and when the pressure rises and the injectors start pulsing longer and faster, if the pump can not keep up. It will lean out your mixture, raise your exhaust temps and cause missing.
Also, the check valve could not hold pressure but it will appear to be fine under light throttle conditions and idle. I just hope your mechanic gave it a good once over and if not, you should make sure to go over it to make sure it not just functioning but functioning perfectly.
