Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-21-2006, 05:52 PM
kboaz2001 kboaz2001 is offline
Turbine Speed Sensor
My son has a 1998 Pontiac Bonneville that displays the error code for "no input voltage signal from the turbine speed sensor" The car runs fine, but what happens if this isn't fixed and how can it be fixed?
Old 11-23-2006, 08:41 AM
maxwedge maxwedge is offline
A990 racer
Re: Turbine Speed Sensor
Welcome to AF. Big job, it is behind the auxiliary valve body under the trans side cover. It could fail an emissions test if the cel is on, depends on the state.
Old 12-01-2006, 07:22 PM
troy1 troy1 is offline
AF -Advisor
Check the trans connector make sure all the pins are good and not out of place. The trans should really run like crap if there was a problem. You should have it checked.
