Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-21-2006, 05:46 PM
garst2328 garst2328 is offline
00 cvpi fluid leak
just got the car and it started grinding and i checked the power stering fluid it was low. so i checked all hoses and they look good . i check the stering gear box and the power stering fluid was spraying out from the butom bolt on it ...... what do i do and can i get by replacing the seal on it any info would be great thanks
Old 12-09-2006, 07:07 PM
rhandwor rhandwor is offline
Re: 00 cvpi fluid leak
Pull the pump and check for defective parts. Roll it over and check for a bad bearing. I would check exactly what you need and the cost of parts.
You can purchase a used one at a yard or a rebuilt unit at a parts store.
Make sure it isn't a cracked fitting from the high pressure hose. A lot of them have a plastic cover that cracks or the o-ring can leak.
