Old 11-21-2006, 03:47 PM
MechanicSuperGirls MechanicSuperGirls is offline
My escort wont start. Got a solution?
I own a 1994 Ford Escort 2 door car. I have one main problem and that is it will NOT start. I am in a mechanics class and have elimated a few options that could have been a solution to the problem one of which is the spark plugs which of course work fine! The car starts then sputters and dies right after I let go of the ignition. When you push on the gas while turning the key it does rev good but then back fires and dies as soon as you let go of the key..... same problem! So, if anyone knows a solution or have a suggestion on what to do, or what to check to help us find out our little problem please reply ASAP I NEED MY CAR BACK!!!!!!!!
Old 11-21-2006, 06:22 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: My escort wont start. Got a solution?
Your timing may be off.
Also make sure the spark plugs are connected in the correct order.
Old 11-21-2006, 07:34 PM
wintonboy wintonboy is offline
I had a problem with my scort not starting when cold. Turned out that the engine coolant sensor was send the brain box the wrong message. Disconnect it ands stick a 56K ohm resistor into the harness and give it a try.
Old 11-21-2006, 08:17 PM
You should also do a compression check if you have the tools... it is quick and easy and will tell you a lot.
Old 11-21-2006, 10:20 PM
KimMG KimMG is offline
AF - Advisor
In addition to what Mightymoose said, check all the vacuum lines. Make sure you don't have a couple of broken teeth on the timing belt.
Old 11-22-2006, 12:10 PM
Cruize Cruize is offline
I would venture a guess that the ignition switch may be bad. Do you have access to some wiring diagrams? You may be able to "hotwire" the car in the "ON" position and then temporarily attach a switch to cycle the starter. If that works, you know it's your ignition switch.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 11-29-2006, 02:13 PM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
sounds like you have loose or bad wires in the ignition. That would explain the back fire after a hard rev and letting go of the key..
Old 11-29-2006, 02:52 PM
Davescort97 Davescort97 is offline
Escort guy
Check to see that the harmonic balancer (aluminum timing ring) hasn't separated from the crank pulley. If it has the belt will be off center.
