Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 11-21-2006, 04:14 PM
demons19 demons19 is offline
Engine Codes
2001 GM/LS
Does anyone know what the codes P0401 & P0402 mean?
And, is this a serious repair?
If anyone knows, I'd appreciate it.
Thanks
Old 11-21-2006, 04:46 PM
Re: Engine Codes
While reading this board, someone wrote;
95% of the time if you get both codes, it is the DPFE sensor.
Is this accurate?
And, is this repair expensive? doable myself?
Thanks
Old 11-22-2006, 07:08 AM
reekor reekor is offline
Re: Engine Codes
Is your DPFE sensor made out of metal or plastic? If it's metal then yes, it may also be covered under warranty depending on the mileage on the car as emissions related part have a longer warranty. It is an easy repair that only takes a few minutes. The part costs about $100 at the ford dealer, do not buy an aftermarket one, they are junk.
Is this accurate?
Thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
