Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-21-2006, 07:00 AM
JJ052653 JJ052653 is offline
1995 Bonneville Air Bag light
I have a 95 Pontiac Bonneville. The Air bag light light is on. This happen once before, but eventually the light went off. Does anyone know were the air bags controls are and were the fuse for the air bags are located ? I believe it might be corrision from water flooding the rear passenger floor. The water is coming in from a good size hole under the rear passegner wheel well.
Old 11-21-2006, 02:54 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Bonneville Air Bag light
The air bag module may be under the rt hand seat, do not work on this without disconnecting the battery for 10 minutes, check for corrosion at the module connector or case. If this is not a problem the system must be scanned for SIRS codes.
