Old 11-21-2006, 02:47 AM
DarrenGR's Avatar
DarrenGR DarrenGR is offline
Riveting Advice!
Hi Guys,
A question for them that know and use in 1/20 and 1/12 scales. Do you fit the after market rivets and spray them in position, or do you spray them and then fit them after the item has been sprayed?? I guess it really depends on whether they are on bodywork - in which case they'd surely be sprayed at the same time as the body? Whereas with rivets on say a bodytub, they'd be more likely to be a slightly different colour as they'd have been attached at the time of building?
Look forward to your comments!
cheers,
Darren
1/20 Lotus 25 & 1/12 Ferrari 165 to be started
1/24 Lancia 037 and 1/9 Ducati currently on the bench!
Old 11-21-2006, 05:46 AM
joelwideqvist joelwideqvist is offline
Re: Riveting Advice!
When I attach after market rivets I look at ref pics to see the color they are supposed to be. If they are in the same color as the part to be mounted on I install them at once. On my bikes I mostly use aluminum rivets when they are to stay that way. BUT, if the rivet is to be a different color than both mentioned above I'd suggest you slide the rivet (if it is the pin type) into position half way, then paint and then pull it all the way in from the back. If it is the dot type I'd suggest you pre paint them.
/Joel
Old 11-21-2006, 06:06 AM
DarrenGR's Avatar
Hi Joel,
The one's I ordered are all pin types as far as I know - got them from scale hardware. Just waiting for them to turn up. I guess the trouble I'm going to have is getting colour shots of the Sharknose under the bodywork to see if the rivets are the same colour or slightly different.
I did see somewhere that some used glitter for rivet replacement on a 1/20 scale car?
Darren
Old 11-22-2006, 01:43 AM
robrex's Avatar
robrex robrex is offline
Darren, that was me. Click on the link to the 312T3 and you can see the progress. I installed the rivets before painting because glitter is way too bright! The other reason I did it that way was because the glitter was glued onto the surface. The rivets you will be using will go into pre-drilled holes which should be drilled before painting.
Rob
Old 11-24-2006, 02:42 AM
DarrenGR's Avatar
Hi Rob,
Thanks for coming back to me and my apologies for the delay in coming back to you. Yes, your absolutely stunning Ferrari F1 build was was I saw the use of glitter, and I will be drilling and fitting the rivets I got from Scale Hardware - now received - before painting as per your advice.
On another note - is there any update on the accessory 'kits' you were looking at producing?
Cheers
Darren
Old 11-24-2006, 06:08 PM
robrex's Avatar
Hi Rob,
Cheers
Darren
Yep! I've already turned two sets of rear wheels and completed the resin inserts. Now I need to make the working wheel nuts and hubs then I'll start on the front wheels.
Rob
Old 11-24-2006, 11:07 PM
klutz_100's Avatar
Darren, I have never heard of Scale Hardware before and I am intrigued.
Could you provide a link, please?
TIA
Old 11-25-2006, 12:24 AM
robrex's Avatar
TIA
Stevenski, Here it is:
http://www.scalehardware.com/
Rob
Old 11-25-2006, 12:45 AM
klutz_100's Avatar
well that was pretty obvious, wasn't it
Thanks Rob!
Old 11-25-2006, 04:43 AM
DarrenGR's Avatar
Hi Rob et al,
saw you got the link to scale hardware and can certainly recommend them for service!
Rob,
By the sound of it you could have a full time job producing these kits for others! Look forward to the next update on these!
On another note, I've got a 037 kit I've been working on for a bit - really must get some pictures taken and posted for other comments.
Darren
