Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 11-21-2006, 02:39 AM
GreyGoose006 GreyGoose006 is offline
tire pressure
just a non biker wondering what kinds of pressure you use in your tires.
i was wondering because with bikes relatively low weight, and big tires, it seems that you wouldn't need to use high pressure. especially when leaning over, the tire has to conform to the road.
but low tire pressures cause wierd tire wear issues.
maybe bikes are like in defiance of traditional rules of car tire pressure, which might be why they are so cool
Old 11-21-2006, 07:08 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: tire pressure
Since the tread section on a motorcycle tire is rounded (to remain in contact the road as you lean), there is a much smaller contact patch than the flat tread on a car. Tire pressure is much more important on a bike, that's why I check my tires more frequently on the bike than my car (although I check my car tires once a week too). A low tire on a bike will cause the tread to flat spot, which can cause a dangerous situation when leaning into a corner. As the tire crests the flat spot, it has very little contact with the road when you need it the most.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-21-2006, 07:20 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: tire pressure
My old hardtail chopper I only ran 10-12 psi in the rear, to save my kidneys...
Old 11-21-2006, 11:32 AM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: tire pressure
i go 34 psi front and rear.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 11-23-2006, 12:26 AM
aussieidiot's Avatar
aussieidiot aussieidiot is offline
Gone crazy! Back soon
Re: tire pressure
on the track i run 30psi cold. when they heat up they get harder.
street 35 front 38 rear.
a low pressure tyre moves on the rim easier causing a softer ride but a less responsive ride. as you corner it is too soft to get feed back
Old 11-23-2006, 05:33 PM
Re: tire pressure
thats what i figured.
so i guess grip isnt really an issue... with wide-ish tires and such a low weight.
Old 11-23-2006, 10:33 PM
DealsGap DealsGap is offline
Re: tire pressure
30 front and rear is a common generic pressure for performance riding on street tires. Some race tires have harder carcasses and require drastically different pressures. Pressures vary from tire to tire, type of use, and conditions. Colder temperatures call for lower pressures to allow more flex which generates more heat. The magic number you're looking for is approximately a 6 psi spread from cold to hot PSI readings. Getting pressures wrong has a direct effect on available grip.
Old 11-26-2006, 04:25 PM
NOBU-SAN NOBU-SAN is offline
Re: tire pressure
33 front. 36 rear. 2006 SV650 factory tire sizes. Handling goes WAY off when pressures are not right. The whole bike seems to handle like trash. When they're low anyways. I sometimes keep them a lb or 2 higher than recommended, but that's it.
1998 Civic EX 2dr MT :Koni RSK suspension, ST 19mm Rear Sway Bar, Hawk brake pads, Civic Hybrid wheels(No bullshit), C- West style front bumper, Apexi N1 cat back, AEM cold air, LSR short shifter... more to come!!! Holler back.
2006 SV650: M4 carbon high mount, racetech springs & oil up front, seat cowl, suzuki frame sliders, new shock coming soon......
Old 12-22-2006, 01:46 AM
UncleBob UncleBob is offline
AF -Advisor
Re: tire pressure
this is kinda like saying tire condition isn't important.
Tire pressure is extremely crucial for bikes. Too much pressure reduces contact patch (and thereby traction) but increases longevity. Too little pressure can cause the tire to buckle in extreme example, just like a car tire, too little pressure will cause the tire to concave and "float" on the bead. Or worse case, the sidewall will callapse and the tire will buckle. In a corner, this will spell disaster. Its also worth pointing out, low pressure can greatly increase steering input, because you are increasing the rolling resistance, which aid/hinders turning effort (aka, lean initiation). Some find this disconcerting, even though (assuming its within reason) it doesn't actually effect handling negatively, just increases physical effort required
There are many factors, such as weight of the bike, type of tires used, temp outside, power of bike and riding style, and have no doubt, if you suddenly changed the pressure of someones tires without them being aware of it, and they were used to X pressure, they very well could crash from it if they attempted to ride as they normally do.
to give an extreme example, my SM (a very light bike) I run 20-25psi front and rear. My ZRX (much heavier, and much higher HP) I run 32-38 in the front and anywhere from 25 to 40 psi in the rear depending on what I'm doing and what the conditions are. Higher pressures are when I'm touring in hotter weather. lower pressures are colder temps and/or racing on a track. For example, running the higher pressures on the ZRX in cold weather, will make the bike slide around like its on ice and make it very dangerous.
Many bikers are completely ignorant of tire pressures though, and thankfully, most of those riders are overly cautious/slow by nature. Its the only thing saving them
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
