Go Back   Automotive Forums Car Chat > Chevrolet > Aveo
Old 11-20-2006, 10:05 PM
junkstardriver junkstardriver is offline
How do I remove front parklamp assembly
There has already been a post on this subject but it didn't help me. I want to replace the right front (passenger side) park/turnsignal lamp assembly...mine was broken in a parking lot incident. I took out the grille, can see the back of the lamp. Then I took out 3 bolts holding the headlamp assembly in, the headlamp is loose but still won't come all the way out. Feels like there is a clip holding it somehow from the side of the headlamp near where it meets the fender. Do I just pull it out of that clip? And will that give access to the park/signal lamp? Thanks for any help.
96 Ford Crapstar GL
96 Olds Cutlass Supreme SL
92 Nissan Stanza XE
00 Nissan Altima GXE
06 Chevy Aveo LS
Old 11-21-2006, 08:18 PM
mikedudley17's Avatar
mikedudley17 mikedudley17 is offline
Send a message via Yahoo to mikedudley17
Re: How do I remove front parklamp assembly
i tried removing mine as well so that i could smoke the lenses and what i think is that the front end may have to come off. i didnt get a chance to look under my car but you may also be right by saying there may be another bracket. this car is goofy for trying to take things off and changing/replacing items
Old 11-24-2006, 01:58 PM
Thanks, I figured it out. The headlamp has a clip on the side that just pulls out. Then the parklamp can be removed if you turn it just right.
96 Ford Crapstar GL
92 Nissan Stanza XE
06 Chevy Aveo LS
