Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 11-20-2006, 08:22 PM
wymi wymi is offline
Question PCV location on a 2001 Altima?
Anyone know where the PCV is located on a 2001 Altima?
Thanks.
Old 11-21-2006, 02:57 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: PCV location on a 2001 Altima?
The PCV valve on Altimas looks different than what has been common for years on most engines. The PCV valve is located at the drive belt side of the engine under the intake manifold and attached to the breather/separator. Access from above is very difficult; access the valve from underneath the vehicle. There is a short hose that connects to the breather/separator. Remove the breather/separator and the hose. Then you can unscrew the PCV valve from the breather/separator for easy inspection and cleaning of each piece. Also inspect both passages where the separator and hose connect. Here is a picture of the valve after it is removed. The breather/separator is a small aluminum housing that will fit in your hand.
http://www.rockauto.com/ref/SMP/SMPD....html?V277.jpg
Obviously the PCV system is more difficult to service on Altima engines than the more familiar design on so many other engines. A restriction in the PCV system will increase crankcase pressure. This pressure inside your engine will push oil out where ever it can find a place to leak, including into the distributor.
Old 11-21-2006, 03:16 PM
Thanks for the info. The PCV I got from the dealer is the push in type and does not have any threads. I believe Nissan changed over to the push in type in 2000. I did figure out the valve is buried under the intake after doing a lot of research. I was hoping the pcv was part of the jittery idle problem I get once the car is warmed up and in gear. I think the problem may be a leaking intake gasket. I am going to spray intake cleaner around the manifold and see if the idle goes up indicating a leak. It seems the intake leak is quite common on these motors. I don't have any engine lights or other symptoms, I am aso going to clean/replace the iac valve & throttle body in hopes that is whats causing the shaky idle.
Thanks again for your response.
Old 11-26-2006, 10:33 PM
futilepursuit's Avatar
futilepursuit futilepursuit is offline
Send a message via AIM to futilepursuit
I read online at Consumer Reports that this valve can be responsible for a light rattle under the hood. My car has a light rattle under the hood. Should I check this PCV thing out?
Old 12-31-2006, 08:35 AM
Can u post the article where u read about the pcv causing a light rattle?
Old 01-06-2007, 06:53 PM
mary pawlowski mary pawlowski is offline
Red face Re: PCV location on a 2001 Altima?
I can not access this webpage?
Has this been taken off or is there another site I can see pictures of
the location of PCV valve?
Old 01-07-2007, 12:28 AM
http://info.rockauto.com/Honeywell/F...436_091906.jpg
Old 10-11-2011, 09:17 PM
Techi Techi is offline
Video on Installation of PCV Valve on Nissan Altima 2001
http://videosdiy.blogspot.com
