Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-20-2006, 08:22 PM
sal111865 sal111865 is offline
1998 Rodeo Transfer case????
I'm getting ready to drop the 5 speed transmision in my Rodeo, I read in my Haynes manual that you drop the tranfer case and manual transmision as one unit. Is this true?
Old 11-21-2006, 12:10 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: 1998 Rodeo Transfer case????
Thats the only way to do it. The xfer case cannot be removed from the tranny. Well, it can but its a major disassembly to do it. It doesnt just bolt to the end like on most 4wds.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 01-17-2007, 09:19 PM
mcdyver1 mcdyver1 is offline
Exclamation Re: 1998 Rodeo Transfer case????
Does The transfer case have to be opened up in order for it to be removed from the transmission ?
please explain the process if possible
Thank you !!!
Old 01-17-2007, 11:12 PM
Gizmo42's Avatar
On the MUA 5speed you pretty much have to disassemble the the whole t-case to get the housing seperated from the trans. So its basicly considered one peice. Most guys who install tera-low gears or do work on the t-case do it without dropping the trans/t-case since its just as much work.
I believe the t-case on automatics can be dropped seperatly though.
THIS POST should give you some idea about it.
--Dave
Rear No-Slip Locker
Old 01-18-2007, 09:55 AM
Thumbs up Re: 1998 Rodeo Transfer case????
Thanks for your fast reply:
The THIS POST will help you link was very helpful and the close up picture was just what I needed.
Thank You Excellent Forum Help !!!
