Old 11-20-2006, 05:44 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
99 blazer 4.3L won't start
A friend came to me at work because of a problem he was having with his blazer.
It is a 99 Blazer 4.3L, it will not start at all, getting Fuel At the injector, good spark, and compression is around 150-160 on each cylinder. And he cannot figure out what the casue could be, the only other problem I could see would be air, but he said they tried holding the gas pedal down while cranking the engine and still no fire.
Anyone have any similar problems or suggestion would be appreciated.
Thanks in advance.........
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 11-20-2006, 07:11 PM
forever3 forever3 is offline
Re: 99 blazer 4.3L won't start
Best guess..... bad timming?
Old 11-20-2006, 07:12 PM
Best guess..... bad timming? timming chain?
Old 11-21-2006, 02:56 AM
DelCoch's Avatar
DelCoch DelCoch is offline
How much fuel pressure?? You need 61 PSI to start engine.
Where is the good spark?? You need to check each and every plug for spark. Just because one plug has good spark doesn't mean the rest do.
Old 11-21-2006, 05:29 AM
muddog321 muddog321 is offline
AF -Advisor
If 6opsi key on engine off and then no bled down, then put a new cap/rotor on (or test with a known working one) - get a Delco cause the aftermarkets have some internal burn thru problems and you don't see and spark is to multiple cylinders at same time - been there. If not that next would be crank sensor.
Old 11-21-2006, 06:21 AM
I will have him check all of the plugs for spark and see where the fuel pressure is at.
