Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 11-20-2006, 04:31 PM
ldhwade ldhwade is offline
Fuel Pump will not engage.
1997 GMC Sierra 305 8 cylinder:
Fuel Pump is not getting power. Does anyone know what would be causing this....everything else works except for the fuel pump?
Old 11-20-2006, 04:36 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Fuel Pump will not engage.
ECM B fuse
fuel pump relay
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-20-2006, 04:44 PM
Fuel Pump has been replaced. Fuel pump relay has been replaced and ECM B fuse tests good.
Old 11-20-2006, 08:40 PM
GMMerlin's Avatar
I know stuff
You say the fuel pump is not getting power..I'm assuming you have checked to the pump and you have no 12v..if the relay and fuse are good, you have an open circuit between the relay and the fuel pump...
GM WCT
PM Me for details
Old 11-21-2006, 09:44 AM
Bob B Bob B is offline
Hi,
The connector outside the fuel tank is known to corrode or burn and fail to electrically connect.
The wires on the fuel pump inside the tank also have had problems and some new pumps come with a new pump pigtail wire, or a note to replace the pigtail.
There is a little wire with a connector thet hangs out of the harness just behind the fuse box on the fender in front of the brake master cylinder. It is where you can jumper 12 volts and cause the pump to go. it bypasses everything and goes directly to the pump. If the pump doesn't run with the wire jumped to 12 volts, then there is a bad wiring from there to the pump, or a bad pump.
Good luck,
Bob B
Old 11-21-2006, 02:00 PM
Tested the wiring this morning and it showed the pump getting 12V. So we went and got yet another new fuel pump....got it home hooked it all up and it worked for maybe 5 seconds....and then it was dead again.
Anymore suggestion
Old 11-21-2006, 02:43 PM
Update:
Took the fuel pump out of tank and tried it...and it works. Put the pump back in tank and it won't. Anyone have any suggestions as to what to look at that would be causing this?
Old 11-22-2006, 07:48 AM
GMMerlin's Avatar
I know stuff
Anymore suggestion
When you checked for 12v how did you do it, DMM, test lamp?
Did you perform a voltdrop test?
did you check grounds?
Check the connector at the sender (where the FP and Sender harness connects to the underside of the sender assembly)..is the connector burnt?
Are the terminals tight?
GM WCT
PM Me for details
Old 11-26-2006, 11:00 AM
rhandwor rhandwor is offline
If you pull the pump again use an ohm meter and ohm the wires from the pump to the connector.
Old 11-26-2006, 11:48 AM
GMMerlin's Avatar
I know stuff
An OHM test is an invalid test for wiring concerns. All it does is tells you there is continuity on the circuit.
A VOLT DROP test will tell you if there is resistance on the wires that could lead to a failure.
It's all about basic electrical theory and OHMS law
GM WCT
PM Me for details
Old 11-26-2006, 12:07 PM
I was just trying to help him with basic tools a home mechanic would have available.
With my ohm meter I can check resistance which causes voltage drop.
Old 11-26-2006, 07:36 PM
We got it fixed. We pulled the fuel pump once again and tested it outside the tank and it ran. Put it back in the tank and it wouldn't. Bent the connecting prongs...and guess they weren't getting good enough contact b/c that seemed to get it to work.
Thanks for everyone's help....it was greatly appreciated.
Old 11-27-2006, 02:24 PM
GMMerlin's Avatar
I know stuff
If you had to bend the prongs, this means the female terminals are deformed.
I would suggest replacing the connector.
GM WCT
PM Me for details
