Old 11-20-2006, 03:26 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
'97, Who's replaced the Oil cooler lines to the Rad.
Didn't find it in the How-to section, so I'll ask here and wait for the move.
I had my cooler lines replaced under warranty back in '98.
The fittings on the filter block side are leaking again (the tubes that run up to the radiator, not the engine block lines)
Here's the question. Picked the lines up today at Napa (same exact Manufacturer that Advance sells for $29.00- I paid $31.00 Napa's walking distance away, Advance is 10 miles).
Inside the bag are 2 small retaining clips- 3 quarter circles about 3/4" dia.
What are they for, the radiator end to hold the hoses on?
I haven't taken it apart yet- but I can see there's no nuts on the tube end for the radiator connections, just plastic sleeve/covers. I'll probably wait till my next day off (Black Friday)
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 11-20-2006, 03:47 PM
Re: '97, Who's replaced the Oil cooler lines to the Rad.
OK, Idiot boy answered his own question.
Took a quick look under the hood at the top tube fitting. Pretty tight in there.
The clip holds the tube into the radiator. So, looks to be about a 30 minute
4 scrapped knuckles job. I'll do it when I change the oil and filter this coming weekend.
Old 11-20-2006, 03:51 PM
Cloud Strife Cloud Strife is offline
Well at least it didn't turn out too bad. Have you turned on the vehicle yet to see if it is leaking anymore?
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I think there are some crush washers you have to use as well.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-20-2006, 03:58 PM
Yep, there's one on the filter block end, nice little retangular aluminum washer with rubber inserts at the inlet/outlet holes. The radiator end has some plastic round caps that slide over the radiator nipples, then the clips go over the plastic caps- caps have 2 small slits for the clips to dig into the hose gittings.
Old 11-25-2006, 07:47 AM
Did the change-out yesterday. Wasn't too bad, didn't scrape ANY knuckles - bonus.
I had to take the air filter box out to get at the bottom radiator hose, that was the most difficult part because of the crammed area my fat stubby arthritic(sp) fingers had to work in. Took about 30 minutes to do, and now no more drip-drip-drip.
The hoses that go to the engine block are still in good shape, but if I ever need to replace those, boy that'll be quite the job. The block connections are right above the transfer case, and there's no room to get at the bolt for the tubes. That one will be a pain.
