Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 11-20-2006, 01:08 PM
Swansen Swansen is offline
Send a message via AIM to Swansen Send a message via Yahoo to Swansen
88 Pickup/ how easy to fix/parts
Hi, i have done a little research and what not, but i was just wondering how easy most repairs are. Also how easy or hard is it to find parts. I'm not for sure on the engine whether it is a 20r, 22r, or 22re. Oh yeah it is a 5 speed manual and is 4WD
Old 11-21-2006, 12:05 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 88 Pickup/ how easy to fix/parts
It's not a 20R, they were 79-80. .
You could look at the sticker on the front of the valve cover, or see if it's carbed (22R) or EFI (22RE).
If it's 4WD it's probably a 22RE.
Parts are easy to find and repairs are easy if you have any experience.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 11-22-2006, 01:27 PM
awesome pretty much what i was looking for, yeah its EFI, yeah so 22re. What about things i should look out for, or common problems. thanks for the info
Old 11-25-2006, 03:40 PM
DM_Rok DM_Rok is offline
Depending on how many miles the engine has on it, there could be a few things to look out for:
Any clatter from the timing chain cover just after startup - this indicates a worn timing chain, and/or guides.
I've heard of exhaust leak problems athe the exhaust manifold due to a cracked manifold or bad flange gasket. However, I have never had this happen to any of my trucks, and have only seen it once at the shop I work at.
If the transmission pops out of gear at all, the shifter seat and cup need to be replaced. Not too difficult, and costs about $30 in parts.
A big problem these have is crud building up in the intake manifold. Open up the throttle valve and take a peek. If you see alot of black buildup that looks like someone was eating brownies in there, clean it out as best ou can with throttle body / carb spray. An inductive intake cleaner that goes in through a vacuum port might also be good
Old 11-28-2006, 02:18 PM
ok thanks for the heads up and advice.
