Old 11-20-2006, 12:37 PM
brady_381need72c10's Avatar
brady_381need72c10 brady_381need72c10 is offline
need help asap!!!
what will take the glue off of a window and black paint off of chrome without destroying the parts!
Old 11-20-2006, 12:44 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: need help asap!!!
How about you start with what kind of glue, and what kind of paint? Clear plastic window, and kit chromed plastic part?
PHOTOBUCKET SUCKS
Old 11-21-2006, 09:12 AM
sorry! here it is-
testors plastic glue
testors black paint<dont know if they are enamal, etc...>
all windows have glue on them and
front grill has black paint on it<chromed>
its this kit if u need to know what kit it is as well!-
Kit #8598.
Old 11-21-2006, 10:54 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
you will NEVER get testors glue off of windows, it etches itself into the surface and fuses together.
The paint, try some rubbing alcohol.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-21-2006, 11:04 AM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
yup, or even a little thinner on a q-tip... just go slowly and delicately and it should come off the bumper. If you end up removing chrome, the best thing you can do is re-cover it with Bare Metal-Foil.
As far as the glue, now that I think about it I've never tried to repair testors tube glue stuck on window glass--it's always been the liquid cement stuff. Since the windows are ruined anyway I'd try the same method though--just sand it as you would if you were polishing a body panel--start with a real course grit to sand it down smoothly, try and get rid of as much of the glue as possible, then sand with increasingly finer grits up until you get into the 12000 grit polishing stuff... then try polishing it. It might turn out useable.
Old 11-21-2006, 11:53 AM
ariel's Avatar
ariel ariel is offline
if you can't get it off let me know. I am working on the 57 cameo at the
present time. I chopped the roof 2 scale inches and can't use the glass in the kit. I also have and extra grill for the 55 in my parts box.
ariel
Old 11-21-2006, 01:35 PM
ZTony8 ZTony8 is offline
If you have (or have access to ) a polishing kit use the cloths in there.Use them just as you would use them on paint and then use the liquid polish and haze remover.Caveat:this soloution doesn't ALWAYS work but at this point you have nothing to lose.Good luck!
Tony Buglione
