Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-19-2006, 04:15 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
turn signals and dash lights
alright a while ago my turn signals just stopped working i checked all the bulbs replaced the flasher itself and they still dont work. well yesterday i went out to start my car and let it run for a while i turned on my lights and bam no interior lights other than my radio. my boost guage my dash gauges nothing lights up at all. i checked the fuse and stuff anyone have any idea what it could be
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 11-19-2006, 09:15 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: turn signals and dash lights
Make sure all the connections on the battery are tight. Does the car run fine? The alternator also may be on it's way out.
95 Talon TSI AWD
97 Eclipse GST
Old 11-19-2006, 09:47 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Yep i hate electrical problems they are definately not my strong suit. Id try a load test on the battery make sure its good. Make sure the alternator is putting out. Try and check continuity of all the fuses with a multimeter. Sometimes u check the fuse and it looks good but could have a small break in it. Check the ones under the hood and under the dash. Did your turn signals work when ur 4ways didnt, or did none of them work? When u replaced the flasher are you sure you got the 4-way and not the turn signal? i think there are two separate. I work mainly on fords chevys and dodges but i have seen problems with the 4ways due to a bad turn signal switch. Again, not sure about dsm's, never seen the problem on them. Also the problem with the headlights and interior lights may lie in the headlight switch, or even a bad ground somewhere else.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-19-2006, 10:29 PM
yea my battery and my alternator are 3 months old maybe, its got to be a wiring issue somewhere im going to call tomorrow and get it checked out. yea it runs fine i just cant drive it at night and i work midnights
Old 11-20-2006, 12:15 AM
Do the flashers work? I know if the flashers are unplugged, the turn signals won't work.
95 Talon TSI AWD
97 Eclipse GST
Old 11-20-2006, 06:55 PM
ill have to look into that when i get a chance maybe the plug came undone or something i dont know
