Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 11-19-2006, 02:26 PM
juggalojesus87 juggalojesus87 is offline
cluth bleeding
having trouble bleeding the clutch system... just replaced everything, master slave the whole clutch line fork arm clutch kit and now all i gotta do is bleed it... it is starting to get on my nerves.
Old 11-21-2006, 03:11 PM
Aruba Racer Aruba Racer is offline
Re: cluth bleeding
Best bet is the use of a power bleeder. Otherwise join [email protected] - there was just a fairly long thread on the topic with a number of good approaches.
Old 12-30-2006, 10:17 PM
racer199 racer199 is offline
Re: cluth bleeding
look on the v8 archie site he has it layed out in laymans terms it works well the problem is the bleeder is located on the wrong end of the slave cylinder so you must press the clutch pedal down and hold it open the bleeder then grab the slave cylinder rod andpull it back into the cylinder then close the bleeder to get all air out of the system most books leave that last step out
Charlie
