Old 11-19-2006, 12:49 PM
forever3 forever3 is offline
Question Having modification electrical problems
I have a 90 s-10 blazer that due to main bearing troubles have been forced to rplace the 4.3l with a vortec 4.3 with high rise intake and Edlebrock 600 carb. i have figured out the fuel issue but cant get spark from the distibutor. I reset the timing from TDC. and have plugged in the oil sensor. is there other sensor that are required? I have tried three differant distibutors, but due to the differance in the intakes, havent plugged any of the harness other than the alt, and oil sensor. what in the computer is not alowwing the spark to pass the ignition module? there is power going into the distributor
Old 11-19-2006, 07:47 PM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Having modification electrical problems
Camshaft Position Sensor? or The Crank Shaft Position Sensor? I belive...
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
