Old 11-19-2006, 12:02 PM
pjfire pjfire is offline
White Milky substance in oil
My daughters 94 GA Quad 4 has a milky substance in her oil when I checked the dipstick. Any ideas on what this is or what is going on?????
Old 11-19-2006, 01:09 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: White Milky substance in oil
That would be moisture or from coolant.
Has it been loosing any coolant lately?
If so I'd STOP driving it till its fixed !
Coolant/water in the oil will ruin your bearings/engine and then you'd need to rebuild it, or replace the engine.
1999 Grand Am SS 3.4 OHV
Old 11-19-2006, 01:17 PM
She just told me when she steps on the gas she hears what sounds like running water.
Old 11-19-2006, 01:55 PM
crazy Jim's Avatar
crazy Jim crazy Jim is offline
yeah, better shut the water off and replace those washers in the faucet
Old 11-19-2006, 02:33 PM
GTP Dad GTP Dad is offline
Pontiac Guy
The water she hears may be water accumulated in the heater box. I would make sure the drain is open by running a coat hanger into the drain. This is located on the firewall near the front of the engine. Also check to see if the drains are open on the doors.
As for the white stuff on the dipstick. Xeroinfinity is right. If you are losing coolant you may want to stop driving. If she only drives very short distances it is possible that this is just condensation that has built up in the crankcase and has not burned off. I would change the oil right away and check the color and the amount. If it looks like chocolate milk you have bigger issues. If it looks normal then condensation is the issue and the oil should be changed more frequently. If the oil looks like chocolate milk don't drive it anymore until you get it fixed.
Old 11-19-2006, 10:30 PM
Also the water running sound could just be the coolant passing through the heater core itself.
Even my 99's do this from time to time.
