Old 11-19-2006, 03:30 AM
nikita7's Avatar
nikita7 nikita7 is offline
Question 1991-1996 GTP question
Hey guys! I got a question to the GP experts about LQ1 engine. Was there a manual transmission (Getrag 284) availible on GTPs with LQ1 produced in 1991-1996 or was it all 4 speed auto ? Also what is the power output of LQ1 ?
Thanks.
1990 TSI AWD.
JDM redtop 4G63T
4 bolt rear end
91 transmission
CF hood
No-name intake
Reverse glow gauges!
Old 11-19-2006, 10:07 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: 1991-1996 GTP question
The LQ1 (also called the Twin Dual Cam) was a special DOHC version of the 3.1 L LH0 V6. It was built from 1991 to 1997. 1991-1993 it used tuned multiport fuel injection, made 200-210 hp @ 5,200 rpm and 215 ft. lbs torque @ 4000 rpm. 1994-1997 it used sequential fuel injection (SFI) making 215 hp @ 5,200 rpm and 225 ft. lbs torque @ 4,000 rpm. It has four large valves per cylinder. The 3.4 L uses a cogged belt to drive the four overhead camshafts. The gearbox options for the LQ1 were a 4 speed Hydra-Matic electronic shifting transmission and a 5 speed Getrag 284 manual transmission, unique to the LQ1. Adapting a pushrod block for overhead cams was difficult, and the 60° vee angle made this a very tall engine, but power output was impressive.
Bore was increased to 92 mm, but the 3.1 L engine's 84 mm stroke was retained. There are only a few interchangeable parts between this DOHC engine and other members of the 60° family, namely the connecting rods and crankshaft.
The heads and intake manifolds were redesigned for the 1996 model year, incorporating a larger throttle body and plenum area, slightly shorter intake runners, cloverleaf combustion chambers, and larger "pill"-shaped exhaust ports. Camshafts and cam timing were also revised for the new, higher RPM powerband.
Applications:
1991-1994 Chevrolet Lumina Z34
1991-1995 Oldsmobile Cutlass Supreme
1991-1996 Pontiac Grand Prix
1995-1997 Chevrolet Monte Carlo Z34
1995-1997 Chevrolet Lumina LS
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 11-19-2006, 03:28 PM
nikita7's Avatar
Thanks for response, I read the Wikipedia info too. I wanted to hear the answer from the person that has the car though.
1990 TSI AWD.
JDM redtop 4G63T
4 bolt rear end
91 transmission
CF hood
No-name intake
Old 11-19-2006, 07:02 PM
BOSTONjoe98gs
hahaha WHATS THE DIFFERENCE MAN,THAT INFO WILL ANSWER BOTH OF YOUR QUESTIONS..WHATS IS THE POWER OUTPUT?? THERE IT IS.....DID THEY HAVE A MANUAL??? THERE IT IS..HAHAHA BUT OK IF YOU NEED SOMEONE WHO OWNS ONE TO TELL YOU THEN MY FRIEND WHO OWNS A Z34 SAYS YES THERE IS A MANUAL AND HE SAID THE SAME THING AS THE SPECS ON THE POWER.HAHAHAH MAN I REALLY DONT UNDERSTAND THAT RESPONCE BUT OK.I WILL LET SOMEONE ELSE CHIME IN.
ubend delete
3in jimmyC downpipe
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
Old 11-19-2006, 07:36 PM
nikita7's Avatar
z34s do have manual transmission. I asked about GTP, it says nothing about GTPs having manual. Manuals are unclear about GTP transmissions. I wanted a response from the owned who actually has a manual GTP with getrag 284, since I think that data is a bit biassed.
1990 TSI AWD.
JDM redtop 4G63T
4 bolt rear end
91 transmission
CF hood
No-name intake
Old 11-21-2006, 08:08 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
According to the info I have, the GTP only offered a manual trans from 91-93, and it was discontinued due to slow sales in 94. The Grand Prix GT was also offered with a 3.1 Turbo and a 5-speed in 91, and with a 2.8/5-speed combo in 88-89.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-01-2009, 12:21 AM
Allard62 Allard62 is offline
Re: '88-
Does anyone anywhere know of a '91 Grand Prix Manual 5 speed trans car for sale complete?
I have a custom project in mind this would be perfect for.
If you know of any plz e-mail me directly: [email protected]
I can't find ANY '88-'91 Grand Prix's with manual trans listed ANYwhere.
ANy leads would be greatly appreciated.
Thank you.
Old 04-01-2009, 12:22 AM
Re: '88-'90
I'm looking for any '89-'91 Pontiac For sale with a manual transmission.
Preferably 3.1L.
I can't find ANY G/P with Manual Trans anywhere. ANYWHERE!
If you know of one, plz kindly e-mail me direct:
[email protected]
Thanks in advance.
Old 04-01-2009, 10:18 PM
lefty1120's Avatar
lefty1120 lefty1120 is offline
Guys......check this out
http://milwaukee.craigslist.org/cto/1101754810.html
