Old 11-18-2006, 10:23 PM
lonerx lonerx is offline
tamiya primer
i got the glass bottle 40ml tamiya primer.. when i shake the bottle. the liquid turned grey.. cus theres some settlements on the bottom.. is tis the way it should be? newbie here anyway..
thanks
Old 11-19-2006, 04:51 AM
stevenoble's Avatar
Re: tamiya primer
Yes,give the primer a good stir before you use it and it will be grey.
Steve Noble
Old 11-19-2006, 07:36 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: tamiya primer
Yeah, that sediment is good stuff. It is what will fill any fine scratches, provide tooth for the paint to adhere to, and protect the plastic from the paint. It is the actual 'primer'.
PHOTOBUCKET SUCKS
Old 11-19-2006, 08:56 AM
Vric's Avatar
Vric Vric is offline
Re: tamiya primer
you are talking about that ?
http://www.tamiyausa.com/product/ite...oduct-id=87075
Old 11-19-2006, 09:56 AM
freakray freakray is offline
AF Modelrater
Re: tamiya primer
If it's what Eric's linking to there, then it's not a surface primer in the true sense, it's a filler.
AF User Guidelines
Old 11-19-2006, 03:47 PM
Vric's Avatar
Re: tamiya primer
this is why I ask.. I wasn't aware that Tamiya primer was available in bottle (I wish it would... damn spraycan cost too much)
Old 11-19-2006, 08:46 PM
ganboy ganboy is offline
Re: tamiya primer
May I add somthing here?
Do you guys apply WHITE primer using AB? I cant find any GOOD white primer for airbrushing from LHS. I found TAMIYA fine primer is the best quality I ever tried but only available in can...I need to skim it off the can every time I want to apply it using AB.
Do you guys has any suggestion on WHITE primer?
Ive seen Gunze's white base an alternative but that pissed me off..it is semi gloss and not opague..
Old 11-20-2006, 01:31 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Re: tamiya primer
In two weeks, I'll be testing Finisher's foundation white (shipped by Rainbow Ten). So I'll post a review once I get it.
Also, this isn't exactly primer, but Modeler's Color White is by far the most opaque white I've ever used, as I demonstrated in this post, so you might want to add it to your next shopping list of kits from Japan. It's synthetic lacquer like Tamiya Spray.
http://www.automotiveforums.com/vbul...9&postcount=85
Hiroaki Fukuda
