Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-18-2006, 09:25 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
greddy e-manage ?
ok, i just bought a greddy e-manage for cheap and i need some info. for one, do i have to have the usb to 9 pin connector? I ask because in the manual it says if you dont have a 9 pin connector on your computer to buy a 9 pin to usb connector... so technically it would be a usb to 9pin-9pin to usb... so isnt that a usb to usb??? Second question. does anyone have the e-manage software? like can someone burn me a copy and send it to me? i would greatly appreciate any help!!! thanks guys!
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 11-18-2006, 09:27 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: greddy e-manage ?
what are you using this for?? You realize that only certain setups will work with Emanage...you have to have a certain injector size and Emanage doensn't have many options at all.....I would use (and do use) Crome...its free and 100x better than Emanage.....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-19-2006, 10:28 AM
eurobeaner's Avatar
if you check out my cardomain, youll see what im running. how is chrome free? and how do you do it, and will e-manage work for my setup?
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 11-19-2006, 10:45 AM
Schister66's Avatar
AF -Advisor
for your turbo setup it probably will work, but all you have to do to get crome is get a chipped OBD1 ECU and download the free software from www.tunewithcrome.com and upload it onto your burner and burn a chip for your ECU (which has to be socketed)
I'm not sure on the details w/ the Emanage, i just have heard a lot of things about it on TurboD16.....it just doesn't seem to be the best system out there.....i know for a fact that you can't use anything bigger than 150% of the stock injector size which limits you right there....I also don't know how it controls timing, but you should search more about it
www.pgmfi.org should have info about it for you
Old 11-19-2006, 05:44 PM
eurobeaner's Avatar
well, i got a used e-manage for $80.... so, i cant beat it. i also got a small laptop to run it already.... i need the software to run it though, and im skeptical to download it off a place like limewire. does anyone know if you have to use the 9-pin?? exactly what will it do if you run usb-usb?
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 11-23-2006, 06:23 PM
eurobeaner's Avatar
any suggestions?
95 Civic EX
H&R sport springs
KYB AGX Struts
CAI
Old 11-25-2006, 10:36 AM
Schister66's Avatar
AF -Advisor
www.pgmfi.org
Old 12-02-2006, 07:38 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
my suggestion is to throwout the emanage. hop on schister's links and educate yourself a little knowledge goes a long way
otherwise, if you are persistent about the emanage. its pretty much self explanatory here.
http://www.mohdparts.com/emanage/man...ual/index.html
and you can waste the rest of your money on the wiring patch here
http://www.autosportwiring.com/products.htm#Honda
good luck.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
