Old 09-14-2002, 04:29 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Wheel bearings
Hey i just found out that i need new wheel bearings in the rear. How much do they cost and how hard is it to install?
Old 09-14-2002, 07:02 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
they are not that hard to install, just make sure you have a large enough socket to get the center nut off, then use a screwdriver to pry the hub assembly off the trailing arm. You'll need to buy the wheel bearing hub assembly, i bought one of mine from NAPA for $90.00.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 09-14-2002, 07:30 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Remember when you tighten that bolt backs down , make sure the hubs still spins free....
try to tighten the nut back down to same spot on the retaining notch on the hub...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 09-14-2002, 08:03 PM
mellowboy's Avatar
Shit only 90 bucks? Everyone told me its expensive! thats not bad from napa! So its not hard to install then i'm gonna do it myself!
Old 09-14-2002, 08:36 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
First of all I don't believe you can just pull the hub out. Everything I've read has said you need a Hub Puller to pull it out and a press to press it back into the knuckle. Good luck doing that with just a screwdriver.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 09-14-2002, 08:53 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
I know on my old CRX it took a shop about an hour and a half to put a rear bearing in it. The bearing cost me 75 bucks on hookup pricing. They charged me an hour labor to put it in ($60). I know that you have to bang the shit out of 4th gen civics to get bearings in and out. Anyone wanna come over and replace my front passenger one? Please? Ill throw in a case of Coronas...
Stop looking at my Autometer!
Old 09-14-2002, 10:47 PM
gunnmen01's Avatar
Rear wheel bearing are much easier to do then the fronts, rears should come off wtih little or no problems. fronts are a different story....
gunnmen01
Old 09-14-2002, 10:57 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
are you guys talkin about the bearing that is like behind and under the hub in the front? i replaced a bearing up there but i forgot what it was called......
2002 Acura TL Type S
1991 Honda Crx Si
