Listen....it's all quiet.
Yep, sort of.
In the attempt to make my hatch quiet, and not so damn noisy, with little squeaks and rattles. I completely tore out my entire interior, being careful not to break stuff either. Oh, this also was a good time to finish getting some of this nasty silver paint out from the previous owner. Anyways, when everything was out, I noticed there was some nasty grime all over. That had to be cleaned out as well. So, to begin I grabbed a bucket of warm soapy water, and my shop vac. Then I scrubbed, cleaned, etc. all the nasty piles of sticky goo, dust, and dirt. Once dried, I sat back and admired how spick and span everything was. Oh, in case you are wondering, it is loud as hell driving down the freeway with nothing but your dash, and driver seat. Next, I wanted to lay down some sound deadening stuff. So I went to the parts store, and picked up four cans of undercoating, which works awsome for this purpose. The down side, is I just added 4.75 lbs of weight to my car . Anyways, I masked off all the important stuff, windows, plugs, etc. Then went to work coating the whole inside bottom half of my car.After 24 hours of dry time, it was time to put things back together. My plan on putting the body panels back on went like this. Grabbing a tube of silicon caulking, I put little dabs of caulk where each part of the interior panels would be snapped into place. This would prevent them from ratteling around, but would be easy enough to pull apart if needed. After everything was put back together, I waited a few hours to go test things out, hoping all the time that my work would pay off. Well......I am glad to say it did. No more rattles, squeaks, or little noises that annoy. Also, the road noise has been significantly cut down. Well worth the three days work, and extra 4 3/4 lbs. :smoker2: |
true enough, my interor is gutted and is loud as hell!
94 Integra LS, autotragic, Tons of mods 93 Accord wagon, Manual conversion and f20b swap in the near future! |
I thought about doing that too... more or less. i was just gonna do the rear part where i have stereo stuff in the spare well.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
does the undercoating dry hard?? or can it come off if you scrape up against it??
Sqeeks you got sqeeks, shit I had those then I got 2 mtx 10s no more sqeeks and alot less time about 2 hours to hook it all up hmmm. I like my time investment better. HEHEHE:flash: :flash: :flash: :flash: :smoker2:
I know what you mean about the squeaks though man, since I don't have my subs in there anymore, I hear them everywhere. Amazing what all noises you hear when your not getting a massage from your subs.
Tony 91 Civic Sedan DX - Stock 287k Miles |
ok i got a squeak i cant fig how to fix! when im goin on bumps or whatever, my rear shocks or body or hatch squeaks. i havent the clue to fixin it, but i have stock suspension...any ideas?
Don't let my car fool you, b/c my treasure is in Heaven! My car is just a slice of it. |
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
lol, I used to be a big sound guy, but got away from that, now trying to learn some more on performance. I think the last time I installed my amp and crossover it might have taken me a little bit longer, because I ran the wires under the carpet on the back of the back seat. Looked really nice.
You guys have the same squeek i had if its the same take off the rear tire and the strut now move the trailing arm toward the car and then toward you if that bushing is bad in the front its where your squeek is coming from. Can also cause a slight shift when going into corners fast and tight.
