Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-18-2006, 05:01 PM
akalima22 akalima22 is offline
Smile 91 engine codes
K ive done searches and cant find accurate answers. My engine is a 3.1 hooked up the two wires and read the codes. code 24 came up hich i cant find anywhere. codes 44 and 45 also show up which i believe is lean signal from o2 and rich signal from o2. So now that i have this info what can i do. What is wrong with my unit. Ive changed plugs wires sensor fuel filter and still nothing. Thanks for ur help.
Old 11-18-2006, 07:45 PM
Re: 91 engine codes
PS. There is only one 02 sensor on the 91 right?
Old 11-18-2006, 08:02 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: 91 engine codes
Yes
2000 VW New Beetle TDI
2007 Honda CR-V
Old 11-19-2006, 08:28 PM
Re: 91 engine codes
bump
Old 11-19-2006, 09:08 PM
Ramblin Fever Ramblin Fever is offline
Re: 91 engine codes
I keep reading this post, I'd love to help you, as I think I'm the only regular on this board that once owned the '91 V6 model year.
But in the whole time I owned that truck - 11yrs/150k+ miles, that CEL never showed it's face, and the O2 was original.
IIRC - the '91 had a distributor, have you changed that? What spark plugs are you running? The 3.1L is the GM/Chevy engine, so I would lean towards parts for the liking of a Chevy engine.
Change the distributor, you mentioned sensor - was that the O2 sensor??
Did you disconnect your battery to clear the codes after installing the new O2?
Also, that's a 15yr old truck, but you didn't mention mileage - your timing chain, if you're over 140k or so, maybe in need of replacing. I do know that at the time that we traded ours in, 155k or so, the chain was getting louder, I knew it was very close to needing done - but we needed a bigger truck, so I didn't spend the money to fix it.
If that chain is weakening, it could cause your timing to be off, which would effect everything.
One more thing, check to see if you have a MAF sensor - I can't remember if it had one or not, and I know I never looked for it either. If you have one, it should be just beyond the air filter in your intake - if you find it, give it a VERY gentle cleaning with MAF sensor cleaner (can be found a pepboys).
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 11-20-2006, 06:37 PM
Re: 91 engine codes
Thanks for the ideas ramblin. And yes the o2 sensor is the one that was changed. I 'll cahnged the distributer cap and i believe the plugs are ngk. As well ive never changed the timing belt i think it must have been done by previous owner. I bought the truck at around 230k and it now has 275k. To be honest my rodeo is a winter beater and just wanna put enough money into it to keep it going. The truck has to many little things wrong with it that its not worth fixing. thanks for all the help.
Old 11-20-2006, 06:55 PM
Re: 91 engine codes
Well if changing the distributor doesn't work; check to see if your timing is correct.
Are you in a situation such as myself, worried about not passing emissions? If you're not, and are not worried about fixing it, then I'd just do the distributor - and see where that leads you.
Is that the automatic or Manual?
1997 3.2L V6 Rodeo
