Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 11-18-2006, 05:35 PM
spudly's Avatar
spudly spudly is offline
2003 Yukon Rough Idle
Hopefully someone has an answer for me!
My 2003 Yukon runs rough at idle and even dies. The other problem is that the problem is intermittent (the worst kind of all automotive problems...) but the problem is becomming more consistent. It has given me a MAF trouble code and Lean Banks 1&2 codes.
I've cleaned the throttle body (as suggested in another posting) but no change. I've changed out the MAF sensor to a Granetelli one in hopes that the MAF error may be connected to the AirRaid intake and TB spacer allowing more air but no change.
Any ideas? (other than going back to stock which is my next option...)
Thanks in advance!
Old 11-18-2006, 07:41 PM
maxwedge maxwedge is offline
A990 racer
Re: 2003 Yukon Rough Idle
Sounds like air is entering the engine behind the maf and not being sensed ,of course this drives the mixture to lean. Bad tb gasket, vacuum leaks and so on. Yes I'd go back to square one also.
Old 11-19-2006, 01:21 AM
spudly's Avatar
Thanks, I was a bit concerned about the cheaply made paper gasket that came with the Poweraid TB spacer so looks like I'll try to spray a little carb cleaner around it and see if the idle cleans up- that'll help narrow down the possibilities. I'll also see if I can get a better TB gasket to go between the TB and the spacer. I wonder if this is a known problem with AirRaid?
Old 12-08-2006, 06:47 PM
spudly's Avatar
Okay, I've tried going back to stock, but no good. I've cleaned the throttle body, and checked for leaks where air could possibly be getting in behind the MAF. Nothing seems to be working. If it were a bit more consistent I'd stand a better chance at this, but it's not. Sometimes it idles high, sometimes it idles low, sometimes it idles just right. Off idle there is no hesistation at all but on idle it stutters and dies. Any more ideas?
Old 12-08-2006, 07:04 PM
A990 racer
Are there any codes now, suggest confirming good fuel pressure and try disconnecting the egr, and/or cleaning the pointle, the lean code is the clue here.
Old 12-09-2006, 06:57 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Check the intake gasket at the head...possible vacum leak
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 12-09-2006, 06:35 PM
spudly's Avatar
It sounds just like an EGR (stuttering, surging, rough idle...)- just like the EGR were letting too much exhaust gas through. So... where is the dang thing? I've looked everywhere and can't find one. I've even looked for a part number and all the online stores are saying one is not available. I have a 2003 with the 5.3L. I'm sitting on about 80k miles so I know its about time for a cleaning.
As for the intake gasket, I haven't ruled that out either. I want to try all the simple stuff before I decide to pull the intake off!
Thanks for all your help, this is just about to drive me nuts!
Old 12-09-2006, 08:38 PM
A990 racer
Hey, maybe there is no egr, I am not sure, I'll pm GMmerlin he's the guy on top of these.
Old 01-02-2007, 03:11 PM
Stealx Stealx is offline
Any update ? I think I have the same exact problem, very noticeable when cold, not really when it warms up
Old 01-06-2007, 12:09 AM
tec5120 tec5120 is offline
coolant temp sensor located at cyl#1 in the head..............
Old 03-12-2007, 08:20 PM
atlantis_my atlantis_my is offline
Wink Re: 2003 Yukon Rough Idle
2002 Yukon: I changed Idle Control Valve ($140), Throttle Position Sensor ($54), and spark plugs but did not fix problem. I removed the cable to the Throttle Position Sensor and the idle became stable (this cable is next to the ICV).
Went to dealer. They measured fuel pressure and it was low. They changed fuel filter and did not improved. Then they changed fuel pump and it fixed the problem (part $500 and labor $500).
Old 08-07-2009, 06:10 PM
pete3006 pete3006 is offline
Any updates on this topic? i have the same problem...changed MAF,Cleaned throttle body,changed fuel filter, Map Sensor,and had Injectors cleaned still rough idle and surge...
Old 08-07-2009, 08:41 PM
A990 racer
2 year old thread. looks like it is dead, no? Anyway I would check fuel pressure and make sure it holds when engine is shut down, 60 is around what you need key on engine off.
