| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
so whats a studderbox
simple as that i have no idea what a studderbox is? and there suppost to be sick so i got to find out what it is.
Will Work For Boost!!! Selling 2000 Eclipse Gs Looking for 1999 Eclipse GsT Spyder |
Re: so whats a studderbox
Stutterboxes give your car more horsepower by assisting the turbo. Barely anyone does it, because it's so expensive. What it does is it delays exhaust before it can power the turbo, so when it finally releases it, it shoots out more boost, therefore making more power because it builds up the power. It's like a really strong blow off valve that builds pressure for more boost.
Just kidding, there was a thread on this no more than a month ago I think. Use the search and you'll find your answer. If you can't find it, try google. If still nothing, use wikipedia. Thank you. |
Studderbox allows you to set what rpm to rev to. Basically it moves the rev limiter. Say you want to launch at 4500rpm, you set the settings on it to 4500rpm. You can then flow it while the car is at a stop and it will rev no higher than 4500rpm. Perfect for launching, thats it.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Studder box is nothing more then the rev limiter. There are 2 types. 2-step and 3-step. 2-step works with the speed sensor. When the car is not moving and the clutch is not compressed the car will rev to it's redline rev limiter setting. When the clutch "is" compressed the car will move the rev limiter to the a lower set value. This puts load on the engine and alows for boost off the line..
The 3-step is a 2-step with one extra feature, it incorprates a third set rev limit while the car is moving and the clutch is being compressed. Also known as NLTS (no lift to shift). That lets you substain boost durring shifts.
DSM geek |
now - 2000 civic soon - 2002 is300
So with a studderbox does that make it so that you cant hurt your engine with a no lift shift...because I have heard horror stories about that....
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
okay so its like the exo 9 where with the clutch in u cant rev past 5. so where does someone pick up a shutterbox... cuz my launch skills blow... im not gonna lie
Summit Racing has them...
-Brian
