Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 11-18-2006, 03:33 PM
mas&NKS's Avatar
mas&NKS mas&NKS is offline
Question 86 Fox body hatch question?
I have an 86 LX, and whenver i close the rear hatch, it dosent latch all the way or something. you can pull up on it and it will pop right open. is there a way to adjust the striker or is the locking mechanism screwed up in it, i know those go bad from time to time. any help would be great, thanks.
Old 11-19-2006, 07:51 AM
b3warnick b3warnick is offline
Re: 86 Fox body hatch question?
It may be the same as my 1987. The striker itself should have a plastic (nylon?) sleeve around it. Mine had been broken and cracked and was not there at all. The lock itself basically only clamps so tight, so if it is clamping around a 'bare' striker....the hatch will just lift right up as you have seen. That sleeve makes for a tighter 'clamp' around the striker. If so, you'll need to probably look on e-bay or get it from Ford. I had no luck at the junkyards as these 'sleeves' being broken is a common occurence. Good luck.
Old 02-28-2007, 12:23 AM
smurfmobile smurfmobile is offline
try penetrating oil on latch, adjust striker.
