Old 11-18-2006, 02:40 PM
Herself11 Herself11 is offline
92 voyager brake booster
Hello I need info on replacing brake booster
92 voyager LE V6 3.3 litre
cant find info anywhere
Old 11-18-2006, 03:11 PM
Scrapper Scrapper is offline
AF Premium User
Smile Re: 92 voyager brake booster
first unhook your master cylinder then under your brake pedal unhook it then there 4 bolts take those off then go back under hood pull it out...no big deal...
Old 11-18-2006, 04:35 PM
KimMG KimMG is offline
AF - Advisor
Many public libraries have professional repair manuals available.
Old 11-18-2006, 05:00 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Welcome on your first post on AF.
Mind tellings us why you are replacing the booster.
If for a hard pedal/with no brakes and you have ABS brakes The ABS brake system is under a life time recall.
Any codes stored in the ABS system?
MT
Old 11-18-2006, 11:35 PM
thankyou all for quick replies .
Not sure about the ABS Id have to ask someonee....
wasnt me
Old 11-19-2006, 12:13 AM
MT-2500's Avatar
AF - Advisor
What are the brakes doing or not doing or why do you want to replace the booster?
MT
Old 10-28-2011, 06:14 PM
tripletsaber tripletsaber is offline
Herself,
I just made almost the same post with the same problem several days ago. I have a 1993 plymouth voyager that needs a ABS accenuator power brake booster(hydraulic) unit. I called every junkyard on the east coast and no one has it and they all told me it would be impossible to get. I found out that you have to go to a locate parts dealer(carquest, napa, autozone) which will in turn get the part from a company called Cardone(cardone.com) and they will send them a rebuilt one but you also have to send them yours because they will rebuild that one and sell it somewhere down the road. i checked with napa and they told me that it would cost about $600+ and then i would have to pay my mechanic to install it. But that is better then buying a brand new unit which goes for about 1500. Iam still debatiing weather to spend the $ or just junk the vehicle since i already replaced it. hope this helps.
Old 10-29-2011, 03:52 AM
MT-2500's Avatar
AF - Advisor
Originally Posted by tripletsaber View Post
Herself,
This post is very old.
On CRY ABS PROBLEMS.
CRY/DODGE had a recall on ABS units and on a lot of them and the recall repair is/was free of charge.
Check with your dealer for recall on them.
MT
Old 10-29-2011, 06:08 AM
MT,
i came across that post, i dont even know how, and just responded to it without looking at the date.
thanks for the info.
Old 10-30-2011, 01:59 AM
TripletSaber...I scrapped my voyager thank you for replying though
wasnt me
