97 rough idle when in gear
I replaced the head,head gasket plugs wires egr valve. Still when i put it into gear,it wants to stall and does most of the time. What else can it be
Re: 97 rough idle when in gear
Is it only when its in drive? What about in neutral?
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
when it it is drive or reverse, neutral is ok.
After searching the contour/msytique forums (www.contour.org) the concensus with people with this problem seems to be a bad trans mount. Take a look and see if your trans is resting on the subframe.
http://www.contour.org/ubbthreads/sh...ue#Post1247599
Which motor?
Does it idle fine till it warms up? or just stall as soon as you shift it , reguardless of engine temperature?
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
There's also the possibility that it's your engine wiring harness as Ford had a recall for this. The wires had a history of cracking and therefore shorting. This can cause stalling because the wiring harness connects to all the sensors and regulates ignition.
