Help With 91 Accord!!!
I have a '91 Accord DX AUTO and the problem occurs while Im driving down the road and the engine just cuts off. For the most part I can throw it into neutral and coast long enough till it finally cranks up again. Some instances I have to wait a few minutes for it to finally crank up. Recently the car cut off 6 times during a 13 mile trip and its becoming a safety hazard for me and other motorists. I've changed out the few filter and hoped I could resolve the problem cheaply but it didnt change a thing. PLEASE ANY ADVICE WOULD BE APPRECIATED!
Re: Help With 91 Accord!!!
And does this happen when you drop the gas, or just cruising along and it lays down? |
Sounds like electrical or fuel problems
1. The first thing I would check is the distributor. Take the cap off and see if there is a layer of orange/brown deposits. If so, clean it up. Then check the igniter to see if it's in good condition. I would say the igniter is very possible the problem. 2. Main relay. But most situation is when it's hot outside and engine will not start. 3. Wiring problem. Maybe a wire got shorted from time to time. This could take forever to find out. 4. Fuel filter. If it's full of water, when the water got into the fuel injecter, the engine will cut off. Then the water level went down and let fuel pass and the engine can be started again. But you said you replaced "few filter". Does it mean fuel filter? 5. Fuel line jammed. Check the fuel pressure. Good luck and let us know what's the fix. |
the car has time to warm up and it usually comes about 5-10 minutes into the drive. Living in FL it never really gets too cold either. The cut off is sudden, just cruising down the interstate and it cuts off with no warning or change in of pressure on the gas pedal. If it is the igniter, do you know if this is an expensive repair? Something I could do myself?
checked the distributor and its clean...Im about to run the car over with a tank and save the trouble. Any ideas on how difficult it would be to replace the igniter?
The electical portion of the ignition switchs go bad on these also.It,s easy to check.When they go bad you can keep the car running by holding in the start postion(only for a very few seconds ,it,s not good on your starter).If it does it,s the eletrical portion of the ignition switch.
With the distribotors ,I have seen rust in them without them being bad.When they go bad,usually there is a code and the customer will complain of a noise under the hood. |
