Old 11-18-2006, 12:08 PM
wingman1305 wingman1305 is offline
Exclamation Please help with my annoying sqeal
I've got a 97 park avenue. If i run it for maybe 20 minutes a squealing starts to sound from under the hood (where it is at specifically I cannot tell). It only gets worse the longer i drive it. But it only seems to squeal when the car idles, it doesn't so much while i'm accelerating. If the car sits for a few hours I can restart and drive another 20 minutes or so til it starts again. I had my friend look at it and we've replaced the belt and alternator but none of that has worked.
All suggestions welcome. Thanks
Old 11-18-2006, 06:00 PM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Re: Please help with my annoying sqeal
It could be a bad tensioner. Why not pop the hood when it is squealing (you said it would at idle), use a dowel rod or bit of pipe and use it to listen for the source of the squeal.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 11-18-2006, 07:02 PM
No success. Just by ear it sounds more towards the backside of the engine near the firewall. My buddy has also suggested things like power steering and pollution filter...still need help.
Old 11-18-2006, 08:46 PM
Joshuas7schev Joshuas7schev is offline
I know it seems to be at the back of the engine. However if the engine is equipped with a supercharger then the front bearing needs to be replaced. Also get the car warm when it begins to squeal very quickly turn the car off remove the belt and start it again only momentarily and this may help eliminate the noise to a moving part associated with the serp belt.
Old 11-18-2006, 09:40 PM
No supercharger.
Your saying start car let it warm to the squeal then shut it off, remove belt and restart without belt?
That would be alotta work for me...removing a belt on that old 3800 isn't very convienient
Old 11-19-2006, 02:32 PM
yutz1 yutz1 is offline
Check to make sure your PCV valve is in place. It's on the passenger side, installed in the top of the black plastic intake manifold. If not present, or loose, it can cause the symptom you described at idle.
This happened to me when I forgot to reinstall it into my new Dorman intake manifold which I had replaced due to the coolant leak that happens eventually with the factory intake manifold on many Park Avenue and other 3800 engine model years (mine a 1998).
Old 11-19-2006, 09:14 PM
Do you possibly have pictures or instructions because quite honestly i'm not sure what it looks like (i'm sure its right in front of my face) and not sure how to check/replace.
Old 11-20-2006, 01:03 PM
J J J J is offline
sounds like the tensioner. They are a trip to replace !!!!
Old 11-20-2006, 02:00 PM
that sounds logical but i used a broom handle to listen to it and nothing was out of the ordinary sounding.
Old 11-20-2006, 03:46 PM
Alibi's Avatar
I'm thinking that the O-ring on the PCV valve is either missing or not sealing correctly. Has this been replaced lately? Theres a good tutorial on the topic that has been linked to in the past, try doing a forum search for it.
Edit: I found the link. Read this forum and the link is posted about 3/4 of the way down.
-Eric
Old 11-20-2006, 10:19 PM
nope it hasn't been replaced recently and i don't see that link your talking about...i tried searching but no luck.
Old 11-20-2006, 11:05 PM
Alibi's Avatar
Oops, my bad. Forgot to paste It was over in the LeSabre forums, but its basically the same car and motor.
http://www.automotiveforums.com/vbul...CV+valve+noise
Post #9 has the link to the tutorial. Although it hasn't been replaced, you may want to consider checking this out to be sure that the O-ring is still seated right...and while you're in there you might as well replace the valve as it is really cheap.
-Eric
Old 11-21-2006, 12:15 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I had a occasional squeal from my PA. Every time time I'd accelerate past a shopping mall entrance from the passanger seat area.
Sorry couldn't resist. The easiest way to identify if it's a belt driven accessory is to remove it and turn them by hand, it's not that hard to remove.
Old 11-21-2006, 04:07 PM
PCV valve replaced...still squeals
Old 11-23-2006, 10:38 PM
so whats my last option here...check the automatic tensioner?
